LS Turbo Comp Ratio
Old Dec 19, 2007 | 01:02 PM
EGLUVN's Avatar
Default LS Turbo Comp Ratio
im boosting an b18b and was wondering if i could run a lower compression ratio before boost. i think stock compression is 9.4 to 1. would it be best to run 9.2:1 or should i run 8.5:1. the reason i ask is because im building an ls to run on just motor until i can afford the turbo parts etc. anybody know?
Old Dec 19, 2007 | 01:45 PM
94TegOwner's Avatar
Default Re: LS Turbo Comp Ratio (EGLUVN)
just leave the comp ratio the way it is, i believe it is 9:1 which is good for boost because 8.5:1 you lose some bottom end power.
Old Dec 20, 2007 | 11:08 PM
EGLUVN's Avatar
Default Re: LS Turbo Comp Ratio (94TegOwner)
thank u. does anybody else have some insight on this topic
Old Dec 20, 2007 | 11:28 PM
Jtuned DC2's Avatar
* B A N N E D *
The way it is should be fine. Not to much not to little. What are your power goals?
greencivic_0789
Feb 18, 2010 09:20 PM
b16racer23
Sep 29, 2004 09:43 AM
Flexin5
Aug 31, 2004 02:58 AM
95'turbotegra
May 25, 2004 05:02 PM
WhitEdRift
Oct 28, 2003 09:03 PM
