ls turbo cams?
Old Sep 9, 2009 | 08:04 PM
Davidls's Avatar
Default ls turbo cams?
im getting ready to build my ls. its already been turboed and now im builing the motor. yes im staying non vtec. im looking to make 350whp to 400whp. i was looking at the crower cams and i was wondering if i can use the stage 3 cams that are 3/4 race or should i just stick to getting the stage 2 turbo cams?
thanks for any input provided
Old Sep 9, 2009 | 08:10 PM
oodie's Avatar
Default Re: ls turbo cams?
I've seen the stage 2 in a hp setup your are looking for and also a good powerband.
Old Sep 9, 2009 | 09:23 PM
Davidls's Avatar
thats good. anyone know anything on how the stage 3's would work on my setup.
my list:
9.3 to 9.8 wiseco
manley h beam rods
crower head(not sure cams yet)
ge intake manifold
skunk 2 t/b
60 trim garrett
e-85
want to get to 350-400whp
Old Sep 10, 2009 | 07:46 AM
Davidls's Avatar
bump
Old Sep 10, 2009 | 10:44 AM
95B18BTurbo's Avatar
JGE 303's are perfect for what you are looking for. They ****ing scream after 4K rpms. Check out the LS-T thread for more details.
Old Sep 10, 2009 | 12:03 PM
Davidls's Avatar
ive heard of those where can you buy those at. can you send me the link
Old Sep 10, 2009 | 12:04 PM
Davidls's Avatar
also thanks for the input
Old Sep 10, 2009 | 02:45 PM
97hb's Avatar
Stock cams will get you 400 depending on turbo.
Old Sep 10, 2009 | 03:22 PM
LightningTeg's Avatar
Community Builder
Really inefficiently. 402ts are hard to beat. Everyone always says JG303s but I've never even heard of the company nor seen any dynos.
Old Sep 10, 2009 | 03:44 PM
gameoverr9696's Avatar
x2
Old Sep 10, 2009 | 03:56 PM
teamcalloway08's Avatar
404's vs the 402T's From a VERY reputable tuner here in Tampa.
Crower 62402T vs Crower 62404 Dyno Comparison We tuned a nice LS setup on Sunoco Maximal. First time in it made 450whp @ 28lbs/29lbs. Felt like something was holding it back. Both in vacuum and in boost. Took the Crower 62402-T cams out. Replaced them with Crower 62404 cams. Also added a 3" -> 4" downpipe. First pull it made 404whp @ 15lbs/16lbs. 470whp @ 19lbs/20lbs. 520whp @ 27lbs/28lbs but blew the intercooler piping off. With the larger 404's the car made this power with three degrees less timing than the 402T's. Made some changes to the intercooler piping. Going to dyno again Monday or Tuesday
Heres the link if anyone cares..
http://www.tamparacing.com/forums/ho...omparison.html
Old Sep 10, 2009 | 04:32 PM
Community Builder
Yeah ok, but 404s are cams for 6000 + rpm powerbands.
Old Sep 10, 2009 | 04:40 PM
Um no...405's maby..Ive had 404's and they make streetable power down low..And if thats a concern then go with the 403's.My point is the 402's are not the best option.
Old Sep 10, 2009 | 05:00 PM
Community Builder
He stated his goal was 350-400. Not 450+
Old Sep 10, 2009 | 05:36 PM
Whatever's Avatar
You've never heard of JG Engine Dynamics?
There is a 800+ LS-T thread and the general consensus is that the JG 303's are the best cams to use with a B18B turbo.
Old Sep 10, 2009 | 06:45 PM
mrbsponge's Avatar
As stated above the 404s hands down.
We have a shop beater integra 18X,XXX miles stock bottom end, ported head, 404s, valvetrain turd-bo-netics turbo, homemade ramhorn manifold
makes 380@17psi runs 11s in a FULL interiored integra with slicks all day
I know the tuner who gave that information above and we both recommend the 404s. the car almost sounds and feels like it has vtec and at 7000 feels like it hits a second time, kinda odd but very awesome.
they can also be made to idle pretty smooth or lope all depends on what you want, and if the tuner can do it with the engine management
Old Sep 10, 2009 | 10:59 PM
As Whatever stated: JG Engine Dynamics
http://www.jgenginedynamics.com
Contact number
Phone / voice mail 626) 281-5326
E mail. jgracingengines@hotmail.com
You cannot order the cams on their site right now, but if you call and state you have a boosted B18B, they will recommend the JGE303. It started out as an all motor cam design, but it worked so well on boosted B18B's that they removed their old boosted cam for the B18B and this is all they will sell now. Trust me when I say at 4000rpms, my car snapped to 8500rpms in 3rd gear. It was one hell of a pull over the stock cams that run out of huff at 6500-7000rpms.
Old Sep 11, 2009 | 02:25 PM
Davidls's Avatar
Contact number
thanks a lot. i e-mailed them and there customer service is great. im looking to purchase them during december. so i can shift at 8500 rpm's after the cams and dual spring and retainer kit?
Old Sep 12, 2009 | 01:33 AM
Yeah, you should have no issues revving to 8500rpms with that setup. I was told to to keep revving until the car stopped making power. I had some issues before I left on my deployment with a bur on a cam gear causing the belt to shred and destroyed my head, but the cams will eventually go back in because the stock head I threw on there real quick is not nearly as fun.
Old Sep 12, 2009 | 06:56 AM
Davidls's Avatar
damn that sucks. how much of a power increase did you see
Old Sep 17, 2009 | 02:10 PM
neophyte210's Avatar
i have turbo ls as well ... and i took stock stuff out and did crower valvetrain and 402-t cams and at 0,0 the car honestly feels slower
im shooting for 380ish on pump
Old Sep 18, 2009 | 03:08 AM
I honestly couldn't tell you because it happened after 200 miles on a fresh engine build, and then again a couple hundred miles afterwards. That is when I got smart and found the burr on the cam gear after destroying two heads and **** canned them for some others I had in the garage. Thank god for forged pistons or I would have really been hosed! I had just started tuning it for more boost, so when I went back to the stock cams I could definitely feel the lack of peppyiness.
Old Sep 20, 2009 | 02:20 AM
Oh, as a side note I would highly suggest a GSR water pump, oil pump, and belt for the higher rpms.
Old Sep 20, 2009 | 08:01 AM
Davidls's Avatar
thats what ive been hearing. i have the oil pump already, just need to get the water pump and belt
Old Sep 20, 2009 | 08:02 AM
Davidls's Avatar
i did type r oil pump. can i do type r water pump and belt?
