ls crank is gsr block.
Old Feb 8, 2004 | 07:34 AM
Silverhatch's Avatar
Default ls crank is gsr block.
I have a friend that will sell me a ls crank really cheap.Its the b18a. would it be worth it to put a ls crank in a gsr block ? What all needs to be done ? thanks
Old Feb 8, 2004 | 07:49 AM
mike1114's Avatar
Default Re: ls crank is gsr block. (Silverhatch)
will fit. Engine girlde may need to be notched a bit to clear the rods.
You gain about 30-40 additional CC's of displacement, and your power curve changes from peak power around 6600rpms to 3750 rpms!!!!!!!!!!!!!!!!!!!!
Edit: this would be the best LS/Vtec you can make!!! NO external oil lines, no mating one head to different block just more power, sooner!!
Old Feb 8, 2004 | 08:16 AM
BOOSTIN1's Avatar
Default Re: ls crank is gsr block. (mike1114)
how about a gs-r crank in a ls block will that work
Old Feb 8, 2004 | 08:23 AM
yimmy's Avatar
Default Re: ls crank is gsr block. (PBOOSTIN)
I was wondering that also. If LS rods and crank were used would it still rev as high and make power at high rpm.
ED9man
May 17, 2008 07:27 PM
dc4teg95
Dec 6, 2006 12:55 PM
black-hatch
Mar 13, 2003 08:54 PM
eddiecut
Aug 20, 2002 10:14 AM
