lowering compression using headgasket?
Old Nov 10, 2005 | 01:32 PM
EH-3's Avatar
Default lowering compression using headgasket?
can compression be lowered by using a specific headgasket? if so, what thickness?
Old Nov 10, 2005 | 02:05 PM
crxvtecturbo's Avatar
* B A N N E D *
Default Re: lowering compression using headgasket? (EH-3)
yes it can be lowered inline pro in va makes a headgasket that will lower your compression
Old Nov 10, 2005 | 02:12 PM
KeyserSoze's Avatar
Default Re: lowering compression using headgasket? (crxvtecturbo)
Yes it can, cometic also makes a thicker hg. I beleive for every .040" thicker is ~1cr lower. At least this is what the people @ cometic say. So a stock hg is .030" and another .040" would make .070" which would lower the cr by ~1.
Old Nov 10, 2005 | 07:59 PM
EH-3's Avatar
Default Re: lowering compression using headgasket? (KeyserSoze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">Yes it can, cometic also makes a thicker hg. I beleive for every .040" thicker is ~1cr lower. At least this is what the people @ cometic say. So a stock hg is .030" and another .040" would make .070" which would lower the cr by ~1. </TD></TR></TABLE>
this info was very helpful. thanks.
Old Nov 10, 2005 | 08:27 PM
BoostR41's Avatar
I ran the inline pro 3mm HG for 2 years on the stock bottom end. I never had one issue with it.
Old Nov 10, 2005 | 10:19 PM
EH-3's Avatar
Default Re: lowering compression using headgasket? (BoostR41)
did u use just the inline pro or that one and the oem one? what motor was this on and how much boost?
Old Nov 10, 2005 | 11:39 PM
BoostR41's Avatar
I used the inline pro 3mm HG. B18C5 14psi daily
Old Nov 11, 2005 | 05:04 AM
PRELUDE-GT35R's Avatar
InlinePro 3mm + 30,000 Miles + 15PSI daily (no winter) = 5G Prelude still running strong
Old Nov 11, 2005 | 06:42 AM
JDM00SI's Avatar
Default Re: lowering compression using headgasket? (PRELUDE-GT35R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PRELUDE-GT35R &raquo;</TD></TR><TR><TD CLASS="quote">InlinePro 3mm + 30,000 Miles + 15PSI daily (no winter) = 5G Prelude still running strong </TD></TR></TABLE>
I wil be using one of these gaskets.
Old Nov 11, 2005 | 10:17 AM
EH-3's Avatar
Default Re: lowering compression using headgasket? (JDM00SI)
why is it that those headgaskets require the use of adjustable cam gears?
Old Nov 11, 2005 | 10:19 AM
BoostR41's Avatar
because you are moving the deck height 3mm so the gears have to dial out the difference
dpetro1's Avatar
the gasket is so thick that it raises the height of the head enough to throw off the cam timing. adj. gears are needed to get everything back to where it is supposed to be at TDC.
Old Nov 11, 2005 | 10:20 AM
dpetro1's Avatar
Default Re: lowering compression using headgasket? (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostR41 &raquo;</TD></TR><TR><TD CLASS="quote">because you are moving the deck height 3mm so the gears have to dial out the difference</TD></TR></TABLE>
lol we answered at the same time. btw i have this gasket as well and my car will see 10psi daily.
Old Nov 11, 2005 | 10:32 AM
EH-3's Avatar
coolness...im running an apex power fc, i think i can adjust timing from my EMS but thats ignition timing. is this totally different from cam timing?
Old Nov 11, 2005 | 11:28 AM
dpetro1's Avatar
yes. cam timing refers to when the cams open the valves. ignition timing is when the spark plugs fire to ignite the air and fuel mixture.
f1 vtec
Jun 25, 2009 08:10 PM
motormike40
Aug 17, 2007 04:38 PM
kidd_drastic
16
Apr 8, 2006 09:11 AM
yz125rider21
Jan 20, 2006 03:03 AM
FyReo3
Jun 5, 2003 11:18 PM
