lowering compression using headgasket?
Yes it can, cometic also makes a thicker hg. I beleive for every .040" thicker is ~1cr lower. At least this is what the people @ cometic say. So a stock hg is .030" and another .040" would make .070" which would lower the cr by ~1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze »</TD></TR><TR><TD CLASS="quote">Yes it can, cometic also makes a thicker hg. I beleive for every .040" thicker is ~1cr lower. At least this is what the people @ cometic say. So a stock hg is .030" and another .040" would make .070" which would lower the cr by ~1.
this info was very helpful. thanks.
</TD></TR></TABLE>this info was very helpful. thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PRELUDE-GT35R »</TD></TR><TR><TD CLASS="quote">InlinePro 3mm + 30,000 Miles + 15PSI daily (no winter) = 5G Prelude still running strong
I wil be using one of these gaskets.
the gasket is so thick that it raises the height of the head enough to throw off the cam timing. adj. gears are needed to get everything back to where it is supposed to be at TDC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostR41 »</TD></TR><TR><TD CLASS="quote">because you are moving the deck height 3mm so the gears have to dial out the difference</TD></TR></TABLE>
lol we answered at the same time. btw i have this gasket as well and my car will see 10psi daily.
coolness...im running an apex power fc, i think i can adjust timing from my EMS but thats ignition timing. is this totally different from cam timing?
yes. cam timing refers to when the cams open the valves. ignition timing is when the spark plugs fire to ignite the air and fuel mixture.
motormike40
Aug 17, 2007 04:38 PM
yz125rider21
Jan 20, 2006 03:03 AM
