lowering compression HG ?
Old Jul 8, 2004 | 06:02 AM
redciv's Avatar
Default lowering compression HG ?
Im gonna make this quick.. to help ya out
95 ex d16z6 eagle rods, arp pistons stock compression stock bore
greddy kit, gonna run 15 lbs
looking to drop the 9.5? CR down to 8.5
found a cometic headgasket SOHC D15, D16, 75mm Bore, .078" Thick
just wondering if this is the correct bore and thickness to drop my cr down a point.
any suggestions are happily welcomed!!!
thank you very much in advance
Rick
Old Jul 8, 2004 | 06:34 AM
tgreaves's Avatar
Default Re: lowering compression HG ? (redciv)
Why do you want to drop your compression down to 8.5:1.. Your perfect at 9.5:1..
Old Jul 11, 2004 | 07:22 PM
redciv's Avatar
i thought that the ideal CR for a boosted car is 8.5 ??
anyone wanna fill me in??? or know the thickness of an upgraded stock head gasket.
I'm not big into the motor building stuff, sorry.. u guys r da best
Old Jul 11, 2004 | 08:28 PM
IntegracinGSR's Avatar
Default Re: (redciv)
There is no said number for what compression ratio is ideal for boosting our motors, its all about preference.. if you wanted you could have 10.5 rather than 8.5:1 CR, its all about tuning..
Old Jul 11, 2004 | 08:32 PM
Default Re: (IntegracinGSR)
If it is a street car and you are going to be running on pump gas, you probably want the lower CR, say anywhere from 9.5:1 to 9:1 or you could even go with your 8.5:1 if ya really want to... but if you're going to be using higher octane race fuel and the car will be for the track then go ahead and go with a higher compression ratio and just make sure you get a good tune.. its all up to you and your goals and preferences..
Good Luck
Dan
Old Jul 11, 2004 | 08:40 PM
J337_UNIT's Avatar
i dont even know if you can get a headgasket which will lower the compression as much as u want... u might be able to lower it to like 9.2:1 which is equal to that of a b18b maybe as low as 9.0:1..im not 100% sure on this.. but i as well think that 9.5:1 CR is fine for boost. 8.5:1 may not be as ideal as you think.. is it safe? yes.. but everything out of boost will feel like ****.
Old Jul 11, 2004 | 11:02 PM
Agreed.. stick with 9.5:1 With a good tuner you shouldn't have any issues..
b00stedOne
Jul 28, 2014 09:56 AM
iceman95
Mar 2, 2006 09:24 PM
GSRerrr
Apr 4, 2005 07:11 PM
fastaccord94lx
May 19, 2003 05:51 PM
sushibug
Apr 3, 2002 05:04 PM
