lower compression stock ecu/injectors?
Old Jan 3, 2006 | 05:44 PM
planeman01's Avatar
Default lower compression stock ecu/injectors?
hey guys-
i come to the FI forum cause you all seem the smartest...yes, i searched-
here's the situation:
I'm rebuilding my b20a (prelude) for boost.
Wiseco 8.5:1 (from 9.1) .020 over pistons
crower rods
stock head (rebuilt)
t3 .42/.48
tial 35mm wg
crome
walbro 255
dsm injectors
6psi
my question: i'm planning on breaking in my motor n/a for a few hundred miles prior to re-installing the turbo. I'm planning on running the stock injectors and ecu for this process. Will the lower compression cause a problem? I've read that i'll have to advance the timing to compensate for the lower compression but other than that i really don't know what the effect will be (other then slightly less power).
What are your experiences with this situation?
should i just break it in with the turbo on and use my tune from before? (i don't think this is a 'perfect' tune) OR should i install the stock in jectors and ecu and hope that the lower compression pistons won't make that big of a difference?
TIA
Rick
Old Jan 3, 2006 | 06:02 PM
platinum00's Avatar
Default Re: lower compression stock ecu/injectors? (planeman01)
you should be fine. I broke in my 1st motor this way and i was 8.5.1
platinum.
Old Jan 3, 2006 | 06:17 PM
Muckman's Avatar
Moderator in Chief
Your fine with the stock ecu. Compression alone wont drastically change power output.
Old Jan 3, 2006 | 06:48 PM
planeman01's Avatar
thats what i was thinking....
If anything i should run a little RICH right?
If so, should i be concerned about washing out the cylinders? whats the general rule of thumb for an a/f where you need to be concerned about washing out the cyls?
thanks for your fast responses!
Old Jan 3, 2006 | 08:40 PM
Muckman's Avatar
Moderator in Chief
Default Re: (planeman01)
it wont be rich, if anything it will be a little lean bc of the slightly larger discplacement. but not significant, the stock o2 sensor should be able to compensate for the difference.
ring wash occurs at uber rich levels <10:1 AFR
Old Jan 3, 2006 | 08:52 PM
planeman01's Avatar
sweet, thanks :thumbup"
ferio 95
Sep 28, 2004 05:37 PM
z6
Apr 9, 2004 06:51 AM
