Low Compression Test Results
Old Mar 5, 2004 | 05:31 PM
Turbo R's Avatar
Default Low Compression Test Results
Motor:
B18C 84mm 9:1.
Results:
#1: 110
#2: 110
#3: 100
#4: 120.
Car runs fine. Valves are loud, and need to be adjusted. Gas sucks. less than 200 miles a tank.
why low #'s?
Old Mar 5, 2004 | 07:00 PM
94gsr4dr's Avatar
Default Re: Low Compression Test Results (Turbo R)
its a little odd that all your numbers are so low, are you sure you conducted the test correctly?
Old Mar 5, 2004 | 07:15 PM
808b18c1boosted's Avatar
Default Re: Low Compression Test Results (94gsr4dr)
Thats what i was thinking also. Engine has to be warm due to expantion,take out all plugs first,open up throttle plate 100%,5 cranks,make shure batt has full charge or hook it up to a charger.
Old Mar 5, 2004 | 07:41 PM
gsrboy18's Avatar
Default Re: Low Compression Test Results (808b18c1boosted)
what should the compression be at for a healthy b18c1?
Old Mar 5, 2004 | 07:45 PM
MaxSterling's Avatar
Default Re: Low Compression Test Results (gsrboy18)
200-210
Old Mar 5, 2004 | 07:46 PM
Mase's Avatar
Default Re: Low Compression Test Results (MaxSterling)
pull the fuse for the fuel pump too
Old Mar 6, 2004 | 09:39 PM
Turbo R's Avatar
Default Re: Low Compression Test Results (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">pull the fuse for the fuel pump too</TD></TR></TABLE>
ill try that.
I took one plug out one at a time and did the test. would that matter?
Old Mar 6, 2004 | 10:01 PM
-iLLuZioN-B18C1's Avatar
when i do mine, i pull them all out.
it also depends if your car is warm or not
and if your pusshing the gas pedal all the way down
i push pedall all the way down, (after the car has been driven a little)
then crank few times.
Old Mar 6, 2004 | 10:04 PM
dunkd's Avatar
wow, thats no good, sounds too low....
Old Mar 6, 2004 | 10:09 PM
Turbo R's Avatar
Default Re: (dunkd)
car was warm and been driven for awhile. pedal was all the way down.
Old Mar 6, 2004 | 10:10 PM
Turbo R's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">wow, thats no good, sounds too low....</TD></TR></TABLE>
wow. ok
Old Mar 6, 2004 | 10:12 PM
TurboJesse
Guest
Posts: n/a
Default Re: (Turbo R)
could the T-Belt be off a tooth or so? The numbers are fairly consistent ...
Old Mar 7, 2004 | 07:48 AM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo R &raquo;</TD></TR><TR><TD CLASS="quote">Valves are loud, and need to be adjusted. </TD></TR></TABLE>That could be your clue.
Old Mar 7, 2004 | 08:23 AM
metal-x's Avatar
Default Re: Low Compression Test Results (earl)
I have similar compression as you Weisco 9:1 and Im gettting
150's across
avotegra
May 25, 2007 11:30 AM
4thgenner
Feb 21, 2006 07:51 AM
EVIL Hx Coupe
Apr 18, 2005 07:34 AM
1FastCoupe
Apr 13, 2005 09:31 PM
Gillard82
Jan 26, 2005 12:39 PM
