Low compression piston broken in before adding turbo kit?
Old Aug 25, 2005 | 06:58 PM
blu3g's Avatar
Default Low compression piston broken in before adding turbo kit?
Hey we'll i want to go boost and i am not familiar with a turbo kit at all. I've gone all motor and it doesn't seem that full filling. So my question would be if i were to throw in some low compression piston, would i have to put that in first and drive it for 2000 + miles and break the pistons in before throwing the turbo kit on, or can i throw in the low comp. piston in and slap on the turbo at the same time and just slowly drive it until it all breaks in? Also, what is all of your opinion on how big should i bore and sleeve my b18c1 block?
Thanks for your input
Old Aug 25, 2005 | 07:00 PM
JDMlyfestyle's Avatar
I know alot of guys that break there motors in without the turbo on. BTW you dont gotta go 2000 miles. search around Rocket had a nice write up on breaking in a motor.
Old Aug 25, 2005 | 07:01 PM
CoreyR's Avatar
Default Re: Low compression piston broken in before adding turbo kit? (blu3g)
2000 mile break in? a couple hundred mile is plenty to seat the rings. just put the turbo on and stay out of boost. i know on my SRT4 the factory recommended 300 mile break in with a few WOT pulls during that period.
Old Aug 26, 2005 | 01:37 PM
blu3g's Avatar
Some people say that driving with low comp. piston will make your car stall very bad. Is this true? Also, doesn't haynes man. recommend driving nicely 500 miles then do an oil change and drive an additional 1500 miles to break in pistons?
Old Aug 28, 2005 | 08:39 PM
Muckman's Avatar
Moderator in Chief
Default Re: (blu3g)
I logged compression test results from my motor break in for the first 3,000 miles. 80% of the highest compression numbers were achieved at mile 500. The last 20% took another 500 miles. I think a few hundred miles is adequate for ring seal.
Old Aug 28, 2005 | 08:54 PM
O16581724 5 2 5's Avatar
I rebuilt my engine, held the RPMs around 2,000 for 10 minutes, changed the oil, then floored it out of my driveway.
Old Aug 28, 2005 | 09:11 PM
ef92b's Avatar
Default Re: Low compression piston broken in before adding turbo kit? (O16581724 5 2 5)
more topics here with pretty good answers:
http://www.mototuneusa.com/break_in_secrets.htm
http://forums.evans-tuning.com...catch
http://www.overboost.com/story.asp?id=1250
Boostin_GSR
Jun 15, 2007 05:26 PM
xxtruoutlawzxx
Mar 14, 2004 03:17 PM
eight grand
Jan 28, 2003 08:48 PM
itr501
May 5, 2002 11:29 PM
TeamTooQuick
Feb 28, 2002 09:46 PM
