Lost Motion Assembly Upgrade
Old Jun 28, 2013 | 12:20 PM
Steeve_Civic's Avatar
Default Lost Motion Assembly Upgrade
I have the choice to put others LMA in my new Head cylinder
On the Right are OEM B16
What do you think about left one?
Thank you
Old Jun 28, 2013 | 12:35 PM
TheShodan's Avatar
Moderator
Default Re: Lost Motion Assembly Upgrade
You're going to get the answer that you should put in the spring type OEM LMA and not the hydrolic ones you currently have. I'll let the others chime in at this point.
Old Jun 28, 2013 | 12:45 PM
ryguy2588's Avatar
DEFINITELY get the spring type. I bought the OEM ones for $200, but now Skunk2 has a set for half price! Get rid of the cylinder ones all together.
http://store.skunk2.com/engine-tunin...-assembly.html
Old Jun 28, 2013 | 12:59 PM
Thks, you advise me to keep the one on the right (OEM B16), or you advice me Springs?
but the ones on the left seem stronger and wider? I think these are GSR ones?
Good, any feed backs? of these
http://store.skunk2.com/engine-tunin...-assembly.html[/QUOTE]
Old Jun 28, 2013 | 01:06 PM
Black R's Avatar
25 Year Member
Which oem spring type is everyone using now?
The new prelude pn?
Old Jun 28, 2013 | 01:39 PM
ryguy2588's Avatar
Originally Posted by Steeve_Civic
[/QUOTE]
I haven't had any experience with the Skunk2 ones yet because I used the OEM ones.
Old Jun 28, 2013 | 01:41 PM
ryguy2588's Avatar
The new prelude pn?
This is where I ordered mine from.
http://www.autodynamics-honda.com/hopclomoas.html
Part number: 14820-PCB-305
You don't need shims with these like the H22 because they already have them on the bottom. These got rid of any "ticking" in my head from the cylinder style sticking.
Old Jun 28, 2013 | 11:39 PM
OK thank you.
Honda doesn't provide anymore the cylinder style ones?
What are the difference between the 2 cylinder style?
Old Jun 29, 2013 | 05:18 AM
nealnanoHX's Avatar
YEah you want the spring style LMA. I have H22 LMA in my Ls Vtec and they work great but need a spacer.
Old Jun 29, 2013 | 06:21 AM
blackeg's Avatar
i used the ones without the spacer and just put in a hardened steel washer from lowes. got about 2000 miles no issues so i think im good to go. they dont seem to be quieter than good condition hydraulic ones, but its nice to know they wont go bad
Old Jun 29, 2013 | 08:11 AM
TheShodan's Avatar
Moderator
^^ So what he's saying Steeve_Civic is that Prelude spring styles are what's used for the OEM. You have to think a little outside the box when it comes to switching out factory components.
Old Jun 30, 2013 | 04:38 AM
blackeg's Avatar
just throwing this out there, but did anyone else notice that the spring type have a slightly smaller diameter and have the smallest bit of side play when dropping them into the head?
Old Jun 30, 2013 | 07:19 PM
wantboost's Avatar
Who is Mr Robot?
I'm curious about the s2 units. If their description is true then I morr than likely know who made the springs. So they should be trouble free
I like the pricepoint as well vs the h22 units but I would like to see and hear real world feedback before investing
Old Jul 7, 2013 | 10:10 AM
turbohf's Avatar
OK thank you.
ones on the left are usualy in obd2 heads the ones on the right are obd0-1. the pointed top early ones are almost always garbage, dont put them in a motor. better off with the ones on the left. if your not buying new oem.
if you push on them and they bind or have freeplay before getting tension then dont use them!
Old Jul 7, 2013 | 02:05 PM
Turbo-LS's Avatar
Spring style OEM here with a washer for spacer here. About 30k miles problem free
Old Jul 8, 2013 | 02:34 AM
wantboost's Avatar
Who is Mr Robot?
Still curious about the skunk2 units
PEDHROTTO
Jul 2, 2012 02:37 PM
promotor
May 20, 2010 11:17 PM
95 integra
May 18, 2004 06:58 PM
Scooby
Sep 6, 2001 05:20 PM
