lose power when v-tech kicks in
Old Aug 1, 2002 | 03:47 PM
lowpsi's Avatar
Default lose power when v-tech kicks in
Hooked up my turbo, everything seems fine until about 5 grand then power just dissapears.....
I think I need more fule but not sure, some one said I had too much fule....
Anyone else have this problem? how did you fix it????
I have a d16 v-tech....
help me out please...
thanx...................Z
Old Aug 1, 2002 | 04:10 PM
TenaciousC's Avatar
Default Re: lose power when v-tech kicks in (lowpsi)
1. there is no such thing as "fule"
2. there is no such thing as "v-tech"
do you have a missing link or check valves? and does the check engine light come on?
[Modified by TenaciousC, 1:11 AM 8/2/2002]
Old Aug 1, 2002 | 04:11 PM
rjardy's Avatar
what in the hell is v-tech?
Rob
Old Aug 1, 2002 | 04:27 PM
Mase's Avatar
Default Re: lose power when v-tech kicks in (rjardy)
You dont know what VTECH is?!?! duh its Very Tedious Evolved Computer Hookers, See they ***** around your ECU, and boom, the little guys inside your ecu(ya know the little guys who tell the car what to do while you just mash the gas) get distracted by these *****, and forget to do their jobs, and next thing you know, parts start to break.
Old Aug 1, 2002 | 05:01 PM
rjardy's Avatar
Default Re: lose power when v-tech kicks in (CDooMe2)
you have a very creative mind my freind
Rob
Old Aug 1, 2002 | 05:04 PM
Mase's Avatar
Nah not really, it took way too long for me to come up with that.....
Old Aug 1, 2002 | 05:17 PM
Tofurky's Avatar
haha, you guys are jerks
too much, or not enough fuel...
what set up are you running?
Edit: Go easy on your car till this is resolved.
[Modified by Ruckus138, 2:19 AM 8/2/2002]
Old Aug 1, 2002 | 05:18 PM
PrecisionH23a's Avatar
Old Aug 1, 2002 | 05:19 PM
Tofurky's Avatar
Default Re: lose power when v-tech kicks in (GudeH23a)
dude my roommate had that phone. vtech rocks!
Old Aug 1, 2002 | 05:28 PM
Vu's Avatar
Vu
What do you have for your fuel system? Injectors, FMU, FPR, S-VAFC, fuel pump, etc.? And how much boost are you running?
When VTEC engages, it dumps more fuel into the system. Try leaning it out a little bit. Do you hear any popping noise, like backfire from your exhaust? That's a sign of running rich. Is your CEL on? Did you dyno your car yet?
Old Aug 1, 2002 | 06:05 PM
dirtySOHC's's Avatar
you tried too hard ............
Old Aug 1, 2002 | 06:42 PM
dustin's Avatar
Default Re: lose power when v-tech kicks in (dirtySOHC's)
I think you need to lengthen the injected pulse
you'll be running nines....
Old Aug 1, 2002 | 06:48 PM
Mase's Avatar
Hey, atleast i try to be cool.
Old Aug 1, 2002 | 08:30 PM
FredoSP's Avatar
u guys crack me up!!
Old Aug 1, 2002 | 09:41 PM
Mr. Softee's Avatar
Default Re: lose power when v-tech kicks in (FredoSP)
hmmm... perhaps you need to advance the timing on your vtech phone a little more... this will allow it to ring sooner so you can pick up calls before they happen
Old Aug 1, 2002 | 09:53 PM
TheIntegraGuy's Avatar
Default Re: lose power when v-tech kicks in (94goldjungsr)
whats your fule setup?
Old Aug 1, 2002 | 09:57 PM
b18cya's Avatar
Old Aug 1, 2002 | 10:26 PM
Cramerox's Avatar
Default Re: lose power when v-tech kicks in (b18cya)
you guys can be so mean sometimes...
Old Aug 2, 2002 | 04:39 AM
EE_Chris's Avatar
Default Re: lose power when v-tech kicks in (Cramerox)
You need to overclock your ECU. Your ECU should have a phone jack installed on the side. Get your vtech phone and plug it in. This will act just like the controller of the PowerFC. Enter 6392 [NEWB] to allow overclocking.
Old Aug 2, 2002 | 05:33 AM
CovertFI's Avatar
Default Re: lose power when v-tech kicks in (EE_Chris)
what turbo are you running? and tell us your fuel setup.
man this thread is ******* funny
Old Aug 2, 2002 | 07:53 AM
98civicEX's Avatar
Default Re: lose power when v-tech kicks in (CovertFI)
It's funny because i did the same thing, running VAFC hack and i had the crossover point for VTEC at 4800, I had major spiking issues, only to find out AFTER i sold my turbo that all the spiking began at VTEC. I was running way to rich....I'm pretty sure you're dumping too much fuel into your system...good luck, if using a VAFC, try disabling VTEC and see how it runs....if it runs okay then it's too much fuel.
Mangudai
Jun 1, 2010 04:45 PM
e-g-6jdm
Dec 3, 2007 02:52 AM
hannahscrx
Oct 18, 2007 08:31 PM
egdriver94
Aug 18, 2006 12:29 AM
TruePlayaz114
Nov 20, 2002 09:21 AM
