loosing power in v-tec
Old Aug 9, 2010 | 10:01 PM
mozzandherb's Avatar
Honda-Tech Titanium Member
Default loosing power in v-tec
Car was on the dyno being tuned with Hondata S100 today and I was loosing power in vtec before it hit 7000rpm, after 7000rpm it didnt gain any additional power when vtec engaged. It's an h22a with a t3/t04e 60-1 turbo with Skunk2 Pro series stage 1 cams. They were adjusted numerous times and it appears that it's either the cams that are too aggressive or that my half-ram horn maniflod doesnt flow enough...any thoughts about these cams and whether they are the right ones?
Old Aug 9, 2010 | 10:13 PM
blackcurrantgsr's Avatar
Default Re: loosing power in v-tec
What is vtec set at to engage? Did your tuner hear any pinging or detonation when it was losing power at 7000rpm?
Old Aug 10, 2010 | 06:40 AM
It doesnt really matter where it was set to engage at because regardless of where it was set it was loosing power. And he didnt mention any detonation or pinging noise but I will double check on that..thanks
Old Aug 10, 2010 | 11:55 AM
When I had my car tuned a few weeks ago on a mustang dyno, right at the cross over point of vtec (about 5600rmp) my tuner heard a few pings, so he added a bunch of fuel there. On my dyno graph there is a noticiable dip in power there, but then it picks up great to 8200rpm. My engine didnt ping or detonate in the high end, only around the cross over point. So thats why asked were the vtec is set, it most likely isnt at 7000 tho right.
Old Aug 10, 2010 | 10:23 PM
looks like the problem might be my manifold. I half a custom made manifold, two of the runners are long and two are short and apparently it doesn't flow enough. The vtec was set at 7000rpm that's because anything before that there was a power loss, no detonation or pinging.
Old Aug 12, 2010 | 12:44 PM
Car made 374whp and 298 ft/lbs tq with no vtec...I want my vtec, but looks like I probably have to change the cams...wonder if this has happened to anyone, I'm guessing it has
Old Aug 15, 2010 | 07:46 PM
bump...still looking for some info
Old Aug 16, 2010 | 07:22 PM
gt30rude's Avatar
what injectors are you using ?
Old Aug 17, 2010 | 07:05 PM
rc 750cc...we checked the fuel pressure, it was fine
Old Aug 23, 2010 | 08:25 AM
still looking for help
autochase06
54
Feb 24, 2013 09:09 PM
EARLdaSQUIRREL
May 24, 2009 05:16 AM
pchan
17
Jan 1, 2008 08:49 AM
ekvtec831
Feb 21, 2004 01:50 PM
dpine
11
Nov 3, 2003 10:20 AM
