Loosing oil HELP!
Old Sep 28, 2003 | 04:10 PM
MRSI00's Avatar
Default Loosing oil HELP!
Guys,
Im running my rebuilt motor, its a b16 with 9.8CR arias pistons and eagle rods. I start to notice im loosing oil because i check my oil level everyday. I dont see any blowby from the breather valve, i had a small leak from the stock oil catch can beside the oil filter, but after replacing the seal and its not leaking anymore. Every 500 miles or so my oil level will be half way between the 1st dot and 2nd dot (that is with heavy boosting 13psi or so daily). I have to pour in like 1/4 quarts of oil when i see that, could it be my turbo burning oil? I check my pipings and i dont see any oil inside the piping, my friends see they see white smoke coming out from my tailpipe occationally when i floor my car before it go into boost. What could it be please advice~!
Old Sep 28, 2003 | 06:40 PM
WIDEHATCHB18CJRSC's Avatar
Default Re: Loosing oil HELP! (MRSI00)
Vtec is meant to burn oil so its probally that. I had that same problem with the breather box on the back of the motor. i was dumping quarts a day until i fixed it.
Old Sep 29, 2003 | 09:14 AM
MRSI00's Avatar
thanks for the reply, anyone else?
Old Oct 6, 2003 | 08:35 AM
MRSI00's Avatar
bump!
highwhey
Nov 11, 2010 05:53 AM
90crxzc
Sep 1, 2003 06:28 PM
Campee
16
May 20, 2003 05:33 PM
EF-9SiR
Dec 16, 2002 11:14 PM
