Looking to get new ignition system. What to get?
#26
Re: Looking to get new ignition system. What to get?
See this thread: http://forum.ectune.com/viewtopic.ph...ht=spark+plugs
I did some comparisons today:
Using NGK 7173 8 Heat Range
Gap .30 @ 19psi 440 / 290 (new plugs)
Gap .25 @ 19psi 415 / 276 2nd pass
Gap .22 @ 19psi 396 / 297 3rd pass
Gap .25 @ 25psi 487 / 342 4th pass
Using NGK 4554 8 Heat Range
Gap .30 @ 19psi 466 / 316 5th pass (new plugs)
Gap .28 @ 19psi 449 / 312 6th pass
Gap .28 @ 25psi 538 / 382 7th pass
Gap .27 @ 19psi 427 / 287 8th pass
Gap .27 @ 25psi 542 / 392 9th pass
Gap .25 @ 19psi 427 / 294 10th pass
Gap .25 @ 25psi 512 / 344 11th pass
coolant temps @ 190-200 Degz.
#27
.018
650/412
24psi
e85 rc1000's
this was recommended by my tuner, and well look at them numbers on the itty bitty 1000's something is working
650/412
24psi
e85 rc1000's
#31
im good my car makes outstanding power on its setup, and gapped at .018
you keep your .040 gap or what ever it is your using
#33
the fuel, and heat range is something that hasnt been mentioned yet
look im not friggin tuner, and only know what my tuner has told me, and he said we gap them low to prevent spark blow out
like i said if you would like to chat with him ill gladly pass along his shops number to you so you can get a better explanation.
#36
98' Integra LS 513whp/366trq 30lbs, pump gas
what size fuel spouts did you make this on, and since its pump gas is this the reason you gap as high as you do wich you havent stated yet what that is
#37
Im not saying dont listen to your tuner, Im saying read up on the subject before telling people ignition systems dont do anything except "clean up the graph".
#38
well when my build was planned and we were having issues my tuner was talking with T1, and guess what was recommended
is that what i said because i was pretty sure i said this/ what the better ign box's do is clean up the signal allowing for a better crisper power band without any sputters in the graph
just incase you missed it the first time
#39
And that's incorrect. It gives the spark more energy so you can run a bigger gap without blowout and make more power.
#40
so it doesnt amplify signal then ok and amplifying it doesnt clean it up over stock
look dud im done with ya and the bullshit arguments here
OP you want a kick *** system do what i said contact T1, and see what he says thats the ebst advice given out in this entire thread that turned into a I read more than this guy so i know more debate.
good luck with your adventures, and only take advice from a great tuner, and T1 is probly the best there is. TATA
#41
You also never said anything about amplifying. Quoting you for the 3rd time
#42
With an m&w pro 14 you shouldn't hav to run that tight of a plug gap. You run 18 thousandths on stock dizzy and 600hp with a good aftermarket unit you should be running a much larger plug gap for a larger spark and more complete burn. I'm running 32 thousandths at 400whp with a summit ignition and crane coil. The m&w should be able to produce more speak energy by probably 20-30k millijoules than what I'm running so having an 18 thousandths gap just doesn't make any sense at all
Yes it cleans up ignition signal and performs better overall but it also drastically increases spark energy which is what's. Needed to open up plug gaps and not have spark blow out. If you have blown out at 650whp with 28-30 thousandths then something isn't working correctly in the m&w setup ImO
#43
#45
Some good info in here, Im having some problems with my setup at just over 300whp. Keep fouling plugs due to weak ignition we think..... debating getting another dizzy and re-locating the coil to external. It was my understanding that OEM dizzys should be fine for this power level.
Also, what are everyone's opinion on ebay distributors? API ignition i think is the brand?
#46
#47
do what ya do ill keep mine tight it make the power on the small setup i have
guess it works so it aint changing
#48
I understand the logic. If it's not broke dOnt fix it but it's kinda like throwing money out the window and it only takes about ten minutes to open the gap on the plugs to test it and if it doesn't work then you can gap them right back down. I would try it for the heck of it but you don't have to
#50
MAde 620 WHP JDM internal coil dizzy off a crate H22 motor, didnt change ****... Not the cap not nothing. not 1 issue.
Sanman, youre only making under 600 right? OEM should manage that ****..
I run a 7AL2 now with nasty coil. To the dude that thinks all the boxes do is "clean" the power... COme grab the end of the coil wire of this ****ing thing.
Hammering gaps down unnecessarily produces sub par idle as well. That said at 759 WHP and 579 TQ I run 4554s at .021-.022 No issue
