LogWorks 2/3 users unite!!!
Old Jan 19, 2008 | 11:50 AM
RACEPAK's Avatar
Default LogWorks 2/3 users unite!!!
hello everyone.
just wondering how many pepole using thw software, i'm using it and i love it, with my rpm converter.
inputs i'm logging are:
rpm
afr
tps
map
i want to log iat and ect but i cant figure out how to set them up,
mabey somone could halme me later on...
well....
UNITE
Old Jan 19, 2008 | 12:42 PM
HiProfile's Avatar
Default Re: LogWorks 2/3 users unite!!! (RACEPAK)
Have you tried the logworks forum? http://www.innovatemotorsports...?f=12 I have the SSI-4 (which I've not had time to setup), but they give you instructions on how to read almost any sensor. They have the PDF's on their website, you might want to look through them again.
Also, what ecu software are you using in which doesn't give you all that info? OBD1 ecu's will send all that data through the datalogging port when enabled. I got a SSI-4 mainly for my carb'd muscle car, and to read pressure sensors on various part of the exterior. CromePro shows me basicly every sensor I need on my Honda.
Old Jan 24, 2008 | 02:02 AM
RACEPAK's Avatar
Default Re: LogWorks 2/3 users unite!!! (HiProfile)
HI profile,
sure, im familiar witn the logowrks forum. but they dont have alot of honda owners there,
i know that i can set up the seneors myself, but its a major pita to adjust the iat&ect, so i thought maby somone have prepared scales for them.
currantly i'm using crome free, looking to buy a used neptune rtp,
i used freelog a bunch of times, and i like it but it seems to be off from my wb reading,
Old Jan 24, 2008 | 01:58 PM
xenocron's Avatar
But it should read your IAT and ECT temps correctly.
use freelog to see the actual temps and take a voltage reading at the same time...get some variance so that you have two points for each sensor and input those points into your LogWorks setup...
Old Jan 25, 2008 | 01:22 PM
RACEPAK's Avatar
Default Re: LogWorks 2/3 users unite!!! (xenocron)
i did it once and entered the resaults in the thersmitor plugin and it didnt worked, klaus says it has a bug.
Old Jan 27, 2008 | 06:21 PM
QuickStyle's Avatar
i use logworks2, its been awhile since i used freelog but if i remember correctly you have to actually set the lambada readings to an afr ratio, i dont think they were set correctly for default. i lost freelog a while ago when my hard drive crashed on my laptop, i lost 100's of tunes and some good tuning programs. i got most of them back, but not all of them.... anyone know of a good download spot for Freelog and BRE? i googled them but didn't come up with much.
Old Jan 27, 2008 | 11:21 PM
RACEPAK's Avatar
Default Re: (QuickStyle)
pgmfi mabey?
Old Jan 28, 2008 | 09:59 AM
QuickStyle's Avatar
pgmfi hasn't worked in a while, im not sure if its for everyone, but i've seen alot of people saying that its been down, and you have to go to forums.pgmfi.org to get to the site, and i can't even log in anymore, it says my account is currently inactive, and you can create a new account cause it wont send you the confirmation email. you have to be logged in to view any posts on there.
when i did have BRE i had to get it from a member on here who emailed it to me, wish i could remember his name. and freelog i just can't find.
Old Jan 28, 2008 | 10:05 AM
RACEPAK's Avatar
well. i'm logged in to pgmfi as i'm writing this message,
freelog:
Beta release1.0.83- 68 :
https://sourceforge.net/project/showfil ... _id=145285
Installer URL: version 1.0.78
https://sourceforge.net/projec...43664
Executable ONLY URL: version 1.0.39
https://sourceforge.net/projec...44545
OCX/DLL support files at
https://sourceforge.net/projec...63045
bre:
http://forum.pgmfi.org/viewtopic.php?f=36&t=8987
thanks to LTdanner & Ben Ogle
Old Jan 28, 2008 | 09:12 PM
QuickStyle's Avatar
thanks for those links, i was able to get the freelog, but the bre link says i have to log in first. and i dont know what it is, but i cannot log into my account and others have said the same thing. says i need to contact an administrator, but i dont know how im supposed to do that if it wont let me view anything... i can view most direct links to the forum post, but i can't get into the actual section of the forum.
95b16rr
Oct 10, 2008 05:11 PM
95civicohyeah
Nov 5, 2007 06:31 AM
MDPL8706
Jul 12, 2006 06:31 PM
Shiftpointshaun
Apr 2, 2004 07:58 PM
Cm91h22a
Apr 16, 2002 12:38 AM
