LM1 with hindata S200
do you know how to connect innovate LM1 to S200? thanks
in hondata for PLX
-Red wire Power cables for the PLX wideband - connect to switched power in the fuse box
-Black Ground - Attach to solid chassis ground
-White 0-5V Output from wideband - connect to ELD input making sure that the ELD is no longer connected to it (ELD is pin D10 on an OBD1 ECU)
-Gray 0-1V Output for narrowband - connect to white wire from stock O2 plug per instructions below
but LM1 have 5 wire color. red, black, white, gray and yellow. anyone know thanks
in hondata for PLX
