little help here please
Old Jul 5, 2006 | 09:33 AM
krazyhmongboi's Avatar
Default little help here please
im putting on a turbo kit and was wonder'n why the bov is not making ani noise..would it be because the internal wastegate is not work'n right? im not shure i connected the wastegate hose is going to the right place..is it suppose to be vacuum?..im jsut not really shure where to hook up the hose thats coming out of the internal wastegate..cuz i got my bov connected with the nipple coming out of the back of the TYPE S bov..thanks for ani help
-another thing-
when i was test driving it..the boost topped at 0 ..would i have to drive it harder for it to pass that 0 mark? or is something just wrong?
Old Jul 5, 2006 | 09:57 AM
yee SERIOUS's Avatar
are you tryin to blow off in neutral?
your wastegate is suppose to be connected to a vaccum source. either off the turbo compressor housing or off the intake manifold.
if your boost gauge shows you at just 0, then you're probably not in boost yet. you gotta step on it more (put more load) for it to go into boost.
make sure your vac lines are hooked up right.
Old Jul 5, 2006 | 01:05 PM
i gota a little nipple thing coming out of the charge piping..does that go to the bov too?
Old Jul 5, 2006 | 06:59 PM
no leaks or anithing..still boost wont go pass 0..wat could be the problem?
krysted9354
May 10, 2009 11:13 AM
asianspeed
Mar 1, 2006 09:34 PM
1FastCoupe
Aug 24, 2005 02:03 PM
jdm-ray
May 15, 2005 09:37 PM
bonestock92si
Aug 19, 2004 01:00 AM
