Little help with a boosted teg
Maybe you guys can help answer some questions i got. I put on my new setup and we wanted to see if the turbo would spool or not. All i put on was the manifold, turbo, and wastegate, with no vaccum hoses connected. Technically it should boost a lil bit, like 1 or 2 pounds right? I rev it a lil bit and i can see the turbine spin a lil, but it wont spool yet. I dont know if my wastegate is broken or not either, i think i might just connect the hoses and see if my wastegate really needs to be connected in order to get spool, but i just always thought if you have at least some exhaust hitting it, that it should spool up. any thoughts?
im gonna try putting everything the way it was on my old setup, but while i try that, any other comments from anyone else?
^^X2
Put it all together than try....ive learned these kinda of things over the years...you wouldnt put a motor half way together and try to start it would you?
AbaZ
Jan 9, 2002 11:05 AM
