Liquid 2 Ar intercooler question
Okay I understand the whole concept of Liquid-air intercooler...Intercooler get water from pump which goes to resivior to heat exchanger..Okay well is it reliable to use this kit
well actually the resivor and pump from this kit and buy a liquid 2 air IC? and work without problems?
That pump is high pressure low volume and that resevoir is tiny. A meth kit is not designed to circulate water through an intercooler, you would spend less money on buying a bigger pump and resevoir and setting it up like you should.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tokes1320 »</TD></TR><TR><TD CLASS="quote">That pump is high pressure low volume and that resevoir is tiny. A meth kit is not designed to circulate water through an intercooler, you would spend less money on buying a bigger pump and resevoir and setting it up like you should.</TD></TR></TABLE>
correct
this is the type of pump you need, its a bosch product, find them on ebay pretty cheap
then use one of these, also found on eaby for cheap!
then get resovoir of some kind, or fuel cell, ****, probably find them on ebay too.
then just get a heat exchanger, or you can use one of those 99 dollar aluminum ebay radiators as one, and help cool more water faster
ebay is the end of the world!!!!
correct
The only reason I thought about that kit was because I couldnot find a resivior seperately I foud the IC with no problme but I could never find a res...and how would I route the thin radiator from pump to rad to IC ???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 001020 »</TD></TR><TR><TD CLASS="quote">The only reason I thought about that kit was because I couldnot find a resivior seperately I foud the IC with no problme but I could never find a res...and how would I route the thin radiator from pump to rad to IC ???</TD></TR></TABLE>
With rubber hose? Use atleast a 1 gallon fuel cell for the water resevoir. Larger resevoir = water stays cooler on the street.
Sinner
Jan 29, 2004 05:05 PM
