limitations of my intercooler
Old Feb 3, 2004 | 02:06 PM
b16ahybrid's Avatar
Default limitations of my intercooler
Ok as you can see in my sig i'm runing a b16 turbocharged..
My question is, about how much hp can the greddy type 26 (approx 16''x5.5''x2.75'') support? It's been modified so the endtanks are normal (had the funky endtank that wrapped back).......it was fine for my set-up when i got it, but my goals have changed..So will this intercooler be a restriction (beyond it's efficiency range) for about 250whp....thanks guys/gals
Old Feb 3, 2004 | 02:35 PM
b16ahybrid's Avatar
Default Re: limitations of my intercooler (b16ahybrid)
anybody using this intercooler?
Old Feb 3, 2004 | 04:00 PM
marc.ejay-twenty's Avatar
i don't know about the ic, but im curious about your setup and at how much boost you made those numbers in your profile. can you give more details? thanks
-marc
Old Feb 3, 2004 | 04:23 PM
b16ahybrid's Avatar
Default Re: limitations of my intercooler (marcdogg816)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcdogg816 &raquo;</TD></TR><TR><TD CLASS="quote">i don't know about the ic, but im curious about your setup and at how much boost you made those numbers in your profile. can you give more details? thanks
-marc</TD></TR></TABLE>
stock b16
garrett t3t40E (.57 trim, .63 ar), drag manifold, 2.5'' exhaust and dp.
rc 310cc injectors, vortec 4:1 fmu, fields sfc,msd 6-al,crane trc-1,ngk plugs.
Suposed to be .65 bar, but it would go up to about 8psi.
Now for some reason it goes to 12 (which works for me)...need to re-dyno it,
mrx
Jun 5, 2005 01:34 PM
b16ahybrid
Mar 10, 2004 06:25 AM
Spooled1.6L
Feb 15, 2004 02:38 AM
blacksi00
May 15, 2003 08:46 PM
jamal
Apr 17, 2003 09:42 PM
