light weight flywheel with 370whp?
Old Sep 17, 2002 | 07:41 AM
austrian type-R's Avatar
Default light weight flywheel with 370whp?
I have the Fidanza aluminium flywheel installed since my turbo project, but I am not so happy with it. Aluminium can not take the heat so well as steel. I guess this flywheel has helped to damage my syncros, cause the clutch can not fully release from the flywheel and the syncros have more stress to bring the speed down. I had some stalling problems too.
Is a lighter flywheel realy that noticeable on my setup? I have no comparison, cause we installed it with the turbo and stuff together. This flywheel goes out for sure, but I am deciding between shaping some material off from the stock flywheel or buy some new light weight cromoly-steel-flywheel....which will cost again too much money
modified stock flywheel (shaping off a few pounds) VS cromoly steel flywheel ---> what are your thoughts
Old Sep 17, 2002 | 09:05 AM
SamC's Avatar
Default Re: light weight flywheel with 370whp? (austrian type-R)
how much whp was your Fidanza fw holding before your turbo setup?
Old Sep 17, 2002 | 09:44 AM
Default Re: light weight flywheel with 370whp? (SamC)
I have not installed it with my setup before the turbo. The Fidanza went in with the turbo, pistons, rods, injectors, Haltech, etc........so I can not compare before and after.
Old Sep 20, 2002 | 07:42 AM
racerxadam's Avatar
bump
Old Sep 20, 2002 | 09:08 AM
Farnsrocket's Avatar
Default Re: light weight flywheel with 370whp? (racerxadam)
"I guess this flywheel has helped to damage my syncros, cause the clutch can not fully release from the flywheel and the syncros have more stress to bring the speed down."
Who told you or how do you know this?????
Old Sep 20, 2002 | 10:10 AM
thejdmkid's Avatar
Default Re: light weight flywheel with 370whp? (Farnsrocket)
aluminum flywheel an turbo = no idle an a big
Old Sep 21, 2002 | 12:56 PM
Default Re: light weight flywheel with 370whp? (thejdmkid)
I have not said, that I know if this is the reason, but it is possible. My tuner thinks about this one too, but of cousre it can not said 100%, until it is taken appart.
Old Sep 21, 2002 | 01:21 PM
Anthony K's Avatar
New User
Wouldn't a shaved stock flywheel be a bad idea with 370whp? It might not be strong enough.
Old Sep 21, 2002 | 01:27 PM
Default Re: light weight flywheel with 370whp? (Anthony K)
You are right, a shaved flywheel can be a bad thing. The stock flywheel is ver thick, so a bit of shaving can not hurt.
You have ever compared a stock flywheel with an lighter one.
My stock flywheel is more than twice thicker than this Fidanza alu flywheel. And stock steel flywheel is for sure stronger than aluminium.
Old Sep 21, 2002 | 01:29 PM
Boostfed's Avatar
New User
I run a JUN lighweight Chromemoly flywheel 10.14 lbs. It has always worked great for me just got it resurfaced for my new build, my numbers before the build were similar to yours very very close. Car accelarated very well with it no idle probs.
Old Sep 21, 2002 | 01:39 PM
Default Re: light weight flywheel with 370whp? (4rcefed)
I have heard, there are some problems woth the starter. The teeth are not so well fitting.
Did you drive your car with an stock flywheel vs an lighter one with an equal setup? Realy that much difference?
How much is spooling up the turbo affected, wehn going with an heavier flywheel. I have heard, that 1/4 Mile runs are not much improved with lighter fyw, cause you loose in the 2nd 1/8 Meile time.
Old Sep 21, 2002 | 01:55 PM
Boostfed's Avatar
New User
I was also worried about the starter problem with the teeth but I never had any probs myself. I lied I have a ZEX flywheel, confirmed with ZEX it is EXACT of the JUN came off the same assembly line . After putting the clutch and flywheel on it felt good, no times to compare, but my car always spooled alot quicker than friends with similar set ups. Cheetah on this board actually stated he dynoed horsepower loss and torwue loss from a lighter flywheel, I don't know if it was an aluminum one real light 7-8 lber. 10 lb aint bad IMHO.
Old Sep 21, 2002 | 08:38 PM
Ri5e's Avatar
I have a 7.5 LB Clutchmasters Flywheel. I didn't notice any difference really between that and my stock 18 LB?
91teggyman
Jul 29, 2006 08:12 PM
EJ8 GSR-T
Jan 30, 2006 10:34 AM
Endoe
Dec 21, 2004 09:45 AM
Reverend
Jun 17, 2001 09:26 PM
