left over engine piece??... plus motor mount question
Old Jan 12, 2005 | 07:53 PM
turbosi03's Avatar
Default left over engine piece??... plus motor mount question
Hey guys, I need your help... I'm going threw tough times now but just got motivated to drop the engine in finally. wondering if I could just post a few misc questions about the engine install
ok fist off... I assembled this motor myself (first time) and I have the dreaded left over part. I can't find it in the helms, nor do I have a clue where it came from, or what its function is...
anyone know what this is??
question 2: these were on the car when I bought it 2 1/2yrs ago, I'm assuming they are stock mounts with after market inserts..? I can't afford a new set, so should I just use like a hassport to replace the rear mount then keep these inserts on the rest?
here's the engine I'm tring to drop as a newb
it's been hanging on those chains for a few months now
hope it works...
thanks for any help!
Old Jan 12, 2005 | 08:02 PM
LSTEG96's Avatar
Default Re: left over engine piece??... plus motor mount question (turbosi03)
dont know what that is, but yes, those are energy suspension mount inserts.... work pretty well, hasport mounts would own though.
sporkcrx's Avatar
Nice looking engine!!! As for the left over piece, it looks to me like it's part of an aftermarket fan bracket. And yea, those are the stock mounts with the ES inserts.
Old Jan 12, 2005 | 08:03 PM
drvfast's Avatar
That is a very clean set-up. Good luck.
Old Jan 12, 2005 | 08:13 PM
turbosi03's Avatar
Default Re: left over engine piece??... plus motor mount question (drvfast)
The tranny side mount does not have the red inserts. is it not needed on that one or am I just missing an insert?
can anyone confirm that to be a fan bracket? (praying thats correct)
I took apart two motors just before this build so I have parts everywhere (plus I moved)...
thanks on the comments!
Old Jan 12, 2005 | 08:16 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">The tranny side mount does not have the red inserts. is it not needed on that one or am I just missing an insert?
thanks on the comments! </TD></TR></TABLE>
Yeah that looks a lot like the bracket that came with my FAL fan.
Old Jan 12, 2005 | 08:25 PM
Aggressive Racing's Avatar
it is definitly the fan bracket from a fal fan,looks like the bottom one.
Old Jan 12, 2005 | 11:10 PM
PrettyLude's Avatar
that's what i was thinking also
Old Jan 13, 2005 | 04:42 AM
nsxmatt's Avatar
Default Re: left over engine piece??... plus motor mount question (aggressivemotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aggressivemotorsports &raquo;</TD></TR><TR><TD CLASS="quote">it is definitly the fan bracket from a fal fan,looks like the bottom one.</TD></TR></TABLE>
Ditto
Old Jan 13, 2005 | 05:27 AM
Rod.'s Avatar
Default Re: left over engine piece??... plus motor mount question (nsxmatt)
at least you have one peice left over.........I had a lot of bolts left over. Dont know where they go and engine been fine inside of car for 4 months. Your engine looks good. What are your horsepower goals and setup
Modified by redturbocivic at 7:50 AM 1/13/2005
Old Jan 13, 2005 | 06:17 AM
getnasty's Avatar
Default Re: left over engine piece??... plus motor mount question (redturbocivic)
**** what mani is that?
Old Jan 13, 2005 | 07:17 AM
turbosi03's Avatar
Default Re: left over engine piece??... plus motor mount question (bottle fed)
aahhhhh!!! the slim FAL fan! thats it, hell yeah I'm so glad it doenst go between the block/tranny or some ****. I'm not even using that fan cause I have another one...
Thanks for looking out guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">at least you have one peice left over.........I had a lot of bolts left over. Dont know where they go and engine been fine inside of car for 4 months. Your engine looks good. What are your horsepower goals and setup
Modified by redturbocivic at 7:50 AM 1/13/2005</TD></TR></TABLE>
haha I hope they weren't big bolts... I have left over bolts also, but again I took two motors apart so I'm hoping they are from the other motor.
I don't really have a HP goal... my main goal is to get this thing running without problems, then my performance goal is to have a nice area under the curve, and see what I can get with around 16psi on pump, possibly 23~26psi on race gas in the future
the internal toys are Benson sleeves 84mm, CP's, Crower rods... the head is ported and stuffed with supertech valve train, and GSR cams.
what you see is and SC44E with custom trim (thanks to Theshodan )
I'll be feeding that with 780cc injectors that will be managed by a Hondata S100
your also looking at a ceramic coated Neukin mani
oh and my fart can will be 3" all the way
Old Jan 13, 2005 | 08:37 AM
00s2KkId's Avatar
^^^^^sounds nice...good luck with it
Old Jan 13, 2005 | 08:55 AM
DaveF's Avatar
Default Re: (96GSRkId)
make sure you put saftey wire on them inserts, otherwise the plastic you have on there currently will break and the inserts will work themselves out overtime.
setup looks/sounds very nice.
Old Jan 13, 2005 | 09:55 AM
msmotorsports's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">The tranny side mount does not have the red inserts. is it not needed on that one or am I just missing an insert?</TD></TR></TABLE>
Your just missing that insert.
Old Jan 13, 2005 | 10:16 AM
turbosi03's Avatar
Default Re: (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">make sure you put saftey wire on them inserts, otherwise the plastic you have on there currently will break and the inserts will work themselves out overtime.
setup looks/sounds very nice. </TD></TR></TABLE>
where can i get a safty wire? is that the two black things on either side of the mount hole? looks like they are zip ties or something...? they're missing on the rear mount in the pic...
I just ordered a hassport rear mount from full race soon as that comes I'm dropping this bitch in
Old Jan 13, 2005 | 10:37 AM
DaveF's Avatar
Default Re: (turbosi03)
saftey wire....... you should be able to find someting at a local hardware store could be in the plumbing section
yes, im talking about the black plastic things rright there. cut them offf, and replace it with wire.
Old Jan 13, 2005 | 10:42 AM
SuperTeg95's Avatar
I've always just ran bolts through the holes instead of the zip ties. It makes the mount more solid and it will never give away with two bolts ran through it with a lock washer and a washer on each end.
Old Jan 13, 2005 | 10:48 AM
Finland's Avatar
Those mount inserts look fine, just re-use them.
pullu
26
Dec 30, 2013 10:00 AM
gunner8541
Honda CR-V & Element
Mar 15, 2011 05:15 PM
LoooseGSR
Oct 11, 2006 09:21 AM
morepoop4u
Aug 31, 2003 10:50 AM
ebelp
May 21, 2002 07:25 AM
