Leak cover in distibutor
Old Jul 11, 2001 | 12:42 PM
boost killz's Avatar
New User
Default Leak cover in distibutor
Just curious to know if the leak cover inside the distributor is really that necessary or if driving a few days without could hurt the distributor?? Unfortuneately for me this crap is on back order and I desperately need to use my car. Thanks
Nick
Old Jul 11, 2001 | 02:08 PM
madslackin's Avatar
Default Re: Leak cover in distibutor (boost killz)
You'll be fine without it. I'd put it in if I had it, but I ran without one for months on my old Integra Plus it's so easy to forget to put back in!
Old Jul 11, 2001 | 07:14 PM
Drag3GSR's Avatar
New User
what does it look like? where exactly does it go? I was told I needed one, but I dont remember taking it off when I went external coil... is it something I should definately replace?
Old Jul 12, 2001 | 08:01 AM
madslackin's Avatar
Default Re: Leak cover in distibutor (Drag3GSR)
If it's what I think he's talking about (the only thing I'd think could be called a 'leak cover') then it's a cup-shaped piece of plastic that matches the distributor cap. If you take off the rotor, this piece slides over the shaft and covers up the electronics in the distributor. You pretty much have to take it off to replace the rotor, which is how I forgot to put it back in a few times.
My guess is that it just protects the electronics from getting wet. I don't know if it's really that important; probably another thing that isn't really "necessary" unless you keep the car for 300,000 miles and drive through lakes and stuff
Don't know why you didn't see it.. maybe it was never there? I wouldn't worry about it either way; as long as your distributor cap makes a good seal I don't see how a bunch of water could get in there.
Old Jul 12, 2001 | 08:26 AM
Drag3GSR's Avatar
New User
Default Re: Leak cover in distibutor (madslackin)
I was told that it helps prevent sparks jumping from the rotor to the other wires/electornic stuff in there when you have an aftemarket ignition/coil
mish__
Mar 26, 2018 05:05 PM
Mandark06
Apr 3, 2007 10:30 PM
devils_civic
Feb 1, 2007 12:06 PM
gsrvx
Dec 20, 2002 10:09 AM
