Launch Control on Engine Management
Old Feb 4, 2003 | 05:37 AM
spike's Avatar
Default Launch Control on Engine Management
I've never heard of this before, but again the guy that's into VW's uses a German engine management I believe.. it's called DTA. He said he uses the stock ABS sensors to sense when the car's front tires are rotating faster than the rear and then it adjusts the timing according.. he says' that once he's done he can get the ultimate launch control with the stock ABS sensors.. does EMS or Hondata have that??
Old Feb 4, 2003 | 06:03 AM
tony1's Avatar
Default Re: Launch Control on Engine Management (spike)
Motec has it , it's called traction control. I believe Autronic has it as well.
Old Feb 4, 2003 | 06:05 AM
spike's Avatar
Default Re: Launch Control on Engine Management (tony1)
that's a pretty damn good idea.
Old Feb 4, 2003 | 07:45 AM
Joseph Davis's Avatar
The DIY version is in the works
Old Feb 4, 2003 | 08:31 AM
nolimits's Avatar
AEM is currently working on this for there EMS.
Old Feb 4, 2003 | 08:38 AM
Tinker219's Avatar
Default Re: Launch Control on Engine Management (J. Davis)
I think I remember a post about that awhile back...please keep us updated on that...sounds VERY interesting indeed...
Old Feb 4, 2003 | 01:11 PM
poid's Avatar
yep Autronic does have it, but i think only the higher-end SM2 rather than the SMC.
Neat ECU's, i will be using an Autronic SMC on my setup. It even has functions for flat shifting and anti-lag in that version, while the SM2 has both traction control and launch control on top of that
Old Feb 4, 2003 | 02:01 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Launch Control on Engine Management (poid)
I think the dta mgmt is garbage. all the cars that run it down here get whooped. this includes porsches,BMW's and the civic's. It might be the one guy that tunes it down here doesnt know what he is doing but I havent seen a car that runs hard with DTA. I believe the DTA only has launch control and not traction control. Thats what i was told.
Old Feb 5, 2003 | 04:27 AM
spike's Avatar
Default Re: Launch Control on Engine Management (MotorMatrix.com)
yeah.. I've never heard of it before.. but I was told it costs 2500 bones! that's ridiculous I think. The guy who uses only works on VWs and he's got some sick cars. He's currently working on his own Porsche he just picked up.. 85 chasis he's made to accept 98 suspension and body panels. He's shooting for 500 street horse and 800 when he cranks up the boost. The other project he's got going on is a corrado VR6 twin turbo. It's going to be mid-engine rear wheel drive. Total custom job.. he said around 30k for the job!!
Anyway... Every VR6 that goes with his turbo system makes at least 385.. that's his minumum and gets DTA. He said it was around 10k to go turbo with the Vr6 because you have to build up the whole drivetrain.. and VW **** is expensive.
Noaman Sharif
May 3, 2017 10:03 PM
HAMOTORSPORTS
15
Oct 6, 2015 10:30 AM
cibao2ner
Engine Management and Tuning
Jan 28, 2011 03:25 AM
dgrave
May 1, 2005 09:13 AM
