Knock meters
Old Jan 1, 2006 | 07:13 AM
crispydee's Avatar
Default Knock meters
Has anyone ever used one of these? Are they any good? i want to monitor knock on my boosted B16.
I dont have a Knock sensor currently so i would have to get one but thats not hard.
http://cgi.ebay.com/ebaymotors...=true
Old Jan 1, 2006 | 07:56 AM
Boostage's Avatar
Default Re: Knock meters (crispydee)
I was thinking of getting one that is circular and fits in a 2 1/16 pod like this..
http://seturbo.com/cat-buick/c...6bcdf
Old Jan 1, 2006 | 08:00 AM
Boostage's Avatar
its audible,so it actually makes noise while the LED's light up.
Old Jan 1, 2006 | 10:33 AM
hondaguyef's Avatar
Default Re: Knock meters (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking of getting one that is circular and fits in a 2 1/16 pod like this..
http://seturbo.com/cat-buick/c...6bcdf</TD></TR></TABLE>
Do you know if that Gauge comes w/ it's own sensor or do you run it off of the OE unit? Thanks
Phil
Old Jan 1, 2006 | 10:38 AM
Boostage's Avatar
gotta buy your own sensor, I think Gm sensors work on hondas and are not too sensitive.
Old Jan 1, 2006 | 10:39 AM
hondaguyef's Avatar
Default Re: (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">gotta buy your own sensor, I think Gm sensors work on hondas and are not too sensitive.</TD></TR></TABLE>
Do you know if it has different sensitivity settings(The gauge that is)?
Phil
Old Jan 1, 2006 | 10:40 AM
komat's Avatar
Default Re: (hondaguyef)
i got the r-500 wideband
it reads knock on it with the stock sensor
Old Jan 1, 2006 | 10:56 AM
Boostage's Avatar
No it doesnt, its a simple $80 peice that you can make for about half of that, you are looking for something with a controller which will cost you.
Old Jan 1, 2006 | 11:02 AM
crispydee's Avatar
Default Re: (komat)
That looks good but is abit more expensive than the one i first posted. I have emailed them tho to see how much the shipping will be to the UK. If its not bad i might get one. Any more ideas would be great.
Old Jan 1, 2006 | 11:07 AM
Boostage's Avatar
Default Re: (crispydee)
the ebay one is cheap because its **** from radio shack. u can make that for $10 in parts.
Old Jan 1, 2006 | 11:45 AM
tallyturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">the ebay one is cheap because its **** from radio shack. u can make that for $10 in parts.</TD></TR></TABLE>
have you ever made one? if so how?
Old Jan 1, 2006 | 12:25 PM
HamiltonRex's Avatar
Default Re: (tallyturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo &raquo;</TD></TR><TR><TD CLASS="quote">have you ever made one? if so how?</TD></TR></TABLE>
I would also like to know!
Old Jan 1, 2006 | 12:27 PM
Boostage's Avatar
No never made one, but I have made a shift light before. and I am not great with electronics.
Old Jan 1, 2006 | 12:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">No never made one, but I have made a shift light before. and I am not great with electronics.</TD></TR></TABLE>
Old Jan 1, 2006 | 07:33 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (HamiltonRex)
all a knock sensor is is a piezo electric sensor which when it detects knock it creates its own voltage, the only hard part about a knock sensor is how you read it, you would have to know at which voltage the knock sensor is creatin enough voltage to which the "knock" is actually "knock" and not engine noise
Old Jan 1, 2006 | 08:50 PM
hondaguyef's Avatar
Default Re: (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote"> the only hard part about a knock sensor is how you read it, you would have to know at which voltage the knock sensor is creatin enough voltage to which the "knock" is actually "knock" and not engine noise</TD></TR></TABLE>
That's what I'm concerned with.
Old Jan 1, 2006 | 08:57 PM
Adi Radoncic's Avatar
On Fire!
The best way to do it would probably be to install the knock sensor on totally stock car see what it reads there than take it to your turbo car and see what it does on there. I think the only big noise makers would be the valvetrain and vtec coming on and those would probably only get to a certain voltage....
Old Jan 2, 2006 | 01:51 AM
crispydee's Avatar
Default Re: (Adi Radoncic)
The thing that concerns me with the ebay one is that it is adjustable. How do you know if you have knock or its just to sensitive? the other one posted looks better.
I suppose you could retard your ignition loads and set up the meter like that so you have no knock then advance your ignition till it changes.
Anyone know where the info is on how to make one?
Old Jan 2, 2006 | 01:08 PM
richeybrooks's Avatar
you adjust it. do a pull through the rpms with no boost, adjust it so there is no noise showing up on the sensor then do your boosted pulls and see the knock.
Old Jan 2, 2006 | 01:24 PM
boostedcivicsir's Avatar
Mr. Badwrench
thats caspers **** and the only bad thing about that, is it needs a buick knock sensor, and you need to drill and tap a 1/4 pipe thread hole for it.
Old Jan 2, 2006 | 01:25 PM
5litereater's Avatar
Default Re: (richeybrooks)
correct me if im wrong but isnt there a setting on some turbo timers (i wanna say apex i) that read a voltage signal which is directly correlated to your knock voltage reading?
essentially your knock sensor should show little to no voltage until there is severe enough vibration for the piezzo crystal to make contact with the terminal in the sensor...which means if you had a voltmeter wired directly into your knock sensor circuit, you could monitor your knock without use of a wideband or expensive gauge setup.
let me know if this sounds far-fetched but it seems like a reasonable, more cost effective alternative.
Old Jan 2, 2006 | 06:30 PM
Si Shane's Avatar
Default Re: (5litereater)
Use a knock sensor and amplify the signal using a tape player and listen to it with headphones.
Old Jan 2, 2006 | 08:30 PM
tallyturbo's Avatar
Default Re: (Si Shane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">Use a knock sensor and amplify the signal using a tape player and listen to it with headphones. </TD></TR></TABLE>
lol
Old Jan 3, 2006 | 11:03 AM
Si Shane's Avatar
lol</TD></TR></TABLE>
You suck, and you don't know ****.
http://home.netcom.com/~bsunda...s.htm
Old Jan 3, 2006 | 03:21 PM
tallyturbo's Avatar
geez chill out it just sounds funny. i wasnt saying it couldnt be done.
