kenne belle boost a pump????
Old Feb 22, 2010 | 08:22 AM
dart2.2's Avatar
Default kenne belle boost a pump????
will the boost a pump work with my a1000 or should i use the aeromotive controller?
Old Feb 22, 2010 | 04:37 PM
tepid1's Avatar
Default Re: kenne belle boost a pump????
The Aeromotive controller works different. It depends on what you're trying to do....
Old Feb 23, 2010 | 04:25 AM
dart2.2's Avatar
keep the a1000 from heating up. i was told if i plan on running this pump for the street i would have to run the pump controller to keep it from heating up/burning the pump up.
Old Feb 23, 2010 | 04:49 AM
SPOOLINmatt's Avatar
yes the BAP will work with those pumps. if you wanted to use the controller im sure it would go, Controller, BAP, Pump in that order of wiring.
Old Feb 23, 2010 | 05:17 AM
dart2.2's Avatar
how do they work differently?
Old Feb 23, 2010 | 08:20 AM
tepid1's Avatar
Ahhh. I thought you were trying to increase pump voltage.... my bad. I ASSumed. lol
I have an Aeromotive that I am not using anymore (basically brand new). If you're interested PM me. I'll let it go cheap!
Old Feb 23, 2010 | 01:56 PM
boostedcivicsir's Avatar
Mr. Badwrench
basically the bap has a hobbs switch installed in line and when a determined boost is reached, it kicks the voltage to the pump up (16v+-?) i cant remember.
personally, thats another thing to go wrong.
when i worked at evo they swear by them, and on the stangs they worked well. but me, if you are going to run the aeromotive in the street, id run the aeromotive controller.
i have never run a large pump on the street so i cant give you 100% input on that. just my exp using baps.
fwiw, all the baps installed by evo, we bypass the the hobbs switch anyway. the sct software has a fuel pump driver paramater that controls that. with the big kenne bells, the boost is instantaneous, and sometimes the fuel is a little laggy, so it is always on and there when needed.
Old Feb 23, 2010 | 03:14 PM
tepid1's Avatar
I would definately use an electrinic trigger as well. Pressure can take time to build and it may already be too late.
Old Feb 23, 2010 | 05:39 PM
Tony the Tiger's Avatar
Make the trigger come earlier, way before the engine maxes out the pump at standard 13.5 volts, then you won't run into the issue.
I have mine set by engine RPM anyway, using an RPM switch.
Old Feb 24, 2010 | 01:38 AM
Mr. Badwrench
with the shelbys it is on all the time, the fuel pump driver modules can also drive the fuel pumps up. the voltage is always there. the "duty" on the driver modules is what is altered.
Old Feb 24, 2010 | 04:43 AM
miller's Avatar
Use the kenne bell boost-a-pump. I love them. Set it up to an output on the ecu so that it will only be active when needed.
Old Feb 24, 2010 | 04:55 AM
dart2.2's Avatar
is that an option with neptune?
Old Feb 24, 2010 | 01:27 PM
Can be done on ECTune, Neptune, or any EMS that has a configrable output (switch to GND).
Old Feb 24, 2010 | 03:08 PM
tepid1's Avatar
Yes, I did it with my Aeromotive controller.
civic-r11
Sep 19, 2011 09:24 AM
Tjabo
Mar 8, 2011 04:26 PM
MIKES
Jan 28, 2011 06:36 PM
senpai
Oct 6, 2002 09:06 AM
