keep the fuel pump or ditch it? w/ 450's?
with 450's, there is no need to upgrade from a stock fuel pump. you can keep the pressure stock since the injectors will be flowing more.
if you're going over 7psi i would upgrade to at least a GSR pump. (or you can add a second pump in the tank with the stock one like the supra guys do- for $20 on ebay you can have enough fuel to run upwards of 25psi of boost.. )
I second the Filthy ScareCrow... If ur gonna boost higher get an uprated fuel pump like a Walbro! Your only gonna need one later so u might as well get one now and be prepared...
