K24 Turbo Options
Old Nov 16, 2005 | 05:36 PM
katzenjammer84's Avatar
Default K24 Turbo Options
The irony of this situation is I'll need two different setups for the same motor in two different cars. Unfortunately while I'm pretty car savvy I'm slightly turbo retarded.
First off, I'm currently saving for an '04 TSX 6MT and should hopefully have it by Spring. I definately have strong interest in doing a turbo. I, unfortunately, have been unable to find any bolt-on kits available for K24A2. Would a kit from the K20A2 work with some modification?
My buddy will also need a kit for his K24A2/K20A hybrid Civic Coupe come Spring. Any insight would be helpful.
Old Nov 16, 2005 | 06:03 PM
ep3_04's Avatar
Default Re: K24 Turbo Options (AcuraFanatic)
Any K20 turbo kit will work. Check out http://www.full-race.com for turbo kits and check out http://www.k20a.org.
Old Nov 16, 2005 | 06:38 PM
Full-Race Geoff's Avatar
the problem with the TSX is that it does not have a throttle cable. Becuase of this, if you want to turbocharge it, you must install a different gas pedal and cable, along with intake manifold and throttle body so you can run KPRO.
If you are up to the task, you can turbocharge your TSX, otherwise dont do it!!
dunerider
Honda Motorcycles
Feb 8, 2007 07:36 PM
themex77
Dec 14, 2004 10:02 AM
Rocket2Acord
Jul 11, 2004 06:29 PM
saso
Sep 13, 2002 10:33 PM
