k20 turbo coolant lines setup
Old Jan 3, 2014 | 06:59 AM
edgarbuilt's Avatar
Any one here knows how to run turbo coolant lines on a k20 hsve been looking and cant find exactly how to do it
Instagram
Edgarbuilt19
Old Jan 5, 2014 | 03:22 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: k20 turbo coolant lines setup
bump.. i need suggestions on where to feed and drain from and to the turbo
Old Jan 5, 2014 | 04:50 PM
edgarbuilt's Avatar
Bump
Old Jan 5, 2014 | 06:27 PM
TheShodan's Avatar
Moderator
You can tap the bottom of your radiator with a -6AN weld bung to -6AN line to turbo. There's also a tap to the water neck directly, or even the Throttle body where coolant bypasses to keep the throttle plate from freezing. Those are the main locations.
thegatekeeper14
Sep 6, 2009 03:04 PM
00boost
Jan 26, 2005 06:33 PM
Soccerking3000
Mar 1, 2004 08:28 AM
nekkedR
Jan 14, 2004 01:19 PM
GruvyTune
Sep 6, 2002 05:09 AM
