K series
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mechman456 »</TD></TR><TR><TD CLASS="quote">what is the best k series block for boost??? </TD></TR></TABLE> best or cheapest...the k24a2 out of the tsx has slightly thicker rods than the k24a1. The k24a1 and k24a2 will yeild about the same amount of c/r. The k24a1 block out of the crv will cost you anywhere from 800-1200 for a full motor. The k24a2 is about 2000-2500. Both will like it especially with the k20a2 head. But if you go with the k20a2 head you can only use the k24a1,a2,a3 motors. In stock form...if your building the motor...any you choose will be fine. But also you can just boost the k20a2 and have lots of fun.
