just put my greddy 15g kit on my sohc...and..
Location: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
just installed a greddy 15g kit on my 96 dx hatchback
everything is on,runs fine
i am runnin missing link, fmu, and inline fuel pump..
everything is connected with a t, all cuplers are tight.
everytime i rev past 4k ish it cuts out
feels like no fuel....
the fuel pump is on,its loud.
fmu is all hooked up right
using stock dx injectors
when i take it up towards 4k it feels like its gonna move but then like pops
i retarted the timing and gappedmy spark plugs to 28-29
whats wrong , im using no engine management
tomorw if i cant get this running right ,im just gonna hook up my afc and runn 450's...
help me!
help me!
Re: just put my greddy 15g kit on my sohc...and.. (honduhh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honduhh »</TD></TR><TR><TD CLASS="quote">
whats wrong? = im using no engine management
Re: just put my greddy 15g kit on my sohc...and.. (ProjectDarkBlack)
iknow.i have a AFC in my room.im gona install.
but i was told..15g on stock boost.. is fine..with
stock civic injectors, fmu and inline fuel pump and missing link? whats wrong?
whoa whoa your lucky you havent blown the engine don not boost a car on stock ecu and no engine management the ecu is pretty much dumping the same amount of fuel in the engine as if the turbo wasnt there. get some injectors and atleast get that afc on there untill you can get crome or uberdata.
Never mind. Try gapping them a little tighter. But your problem definitley sounds like a management one.
Get something better than stock injector/fmu setup. I tried that crap with my first kit and had the same problems. Sell all that stuff and upgrade your injectors and run a chipped ecu. Or if you don't have the money run some bigger injectors and your safc that you already have.
Re: (93turbo16)
i also have 450 dsm..and a apexi afc.. debatin if i shud just ditch all the fmu crap and do the afc hack?
Re: (honduhh)
listen to people. Dont run an afc or fmu. Run some real engine managment. Also your distributor shouldnt need retarded all the way. How much boost are you running? If your running 5-6psi a base timing of 10* will probably be plenty safe, but it will probably run like poo out of full boost.
Re: (SOHC_MShue)
im runin stock 6 lbs
its not retarted all the way
the fuel pump is mounted on the line between the fuel rail and the feul filter...
i wanna run real managment but i wanna get this running good first.
shud i just ditch all the fmu,,inline pump all together.and just run 450cs with resistors and my afc?
i dont have any check engline light!
Re: (honduhh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserieskllr »</TD></TR><TR><TD CLASS="quote">yea and the 96-00 dx injectors arent they 190cc's????? maybe thats a problem...</TD></TR></TABLE>
yea but greddy said it was fine.. on stock 6lbs.
fmu, missing link and inline fuel pump to run stock injectors
should i try to figure out whats wrong with this fmu/ missing link thingg....
or just ditch it for dsm 450s and afc.. i wil do a good ecu/ setup managment soon.
but for nowwww..whic one
Re: (SOHC_MShue)
then do what??????????????????????
i need to rev past 4k with boost. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">pgmfi.org</TD></TR></TABLE>
good site..but i need a quick fix.. i dont have a thing to burn a ecu..and i have a obd2 ecu... i need to figure out what to make my car work right
the dsm injectors and afc hack are fine for the time being but i would look for someone to chip my ecu and tune it correctly asap... good luck
-Josh
-Josh
Re: just put my greddy 15g kit on my sohc...and.. (Crimson_Tide)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crimson_Tide »</TD></TR><TR><TD CLASS="quote">the dsm injectors and afc hack are fine for the time being but i would look for someone to chip my ecu and tune it correctly asap... good luck
-Josh</TD></TR></TABLE>
thats what im thinkin.. i had the afc hack on my older eg hatch
years ago. never had a problem..
Re: just put my greddy 15g kit on my sohc...and.. (Ls1 FD3s)
iknoww.. but im tryin to work with what i got for now
You need more fuel, nuff said. Those injectors are pushing way too much fuel pressure and can possibly seize up entirely.
Don't half *** it and then complain two weeks later that your motor blew, and Greddy sucks, blah blah blah. You knew the risks, why push it?
Re: just put my greddy 15g kit on my sohc...and.. (Finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest »</TD></TR><TR><TD CLASS="quote">You need more fuel, nuff said. Those injectors are pushing way too much fuel pressure and can possibly seize up entirely.
Don't half *** it and then complain two weeks later that your motor blew, and Greddy sucks, blah blah blah. You knew the risks, why push it? </TD></TR></TABLE>
haha who are you ha
haha who are you ha
