just got retune...whats wrong?
Old Sep 11, 2005 | 09:37 AM
tony n.'s Avatar
Default just got retune...whats wrong?
my friend just got his car retune by tony1 he made 272whp 194lbstq @18psi
setup:
b16a: 8:1 pistons eagle rods i dont know what kind of pistons...and i think theyre eagles...
turbo: inlinepro mani, tial wg, supposely sc61...2 3/4 downpipe 3" exhaust drag intercooler drag pipin, 780cc injectors, 255 fuel pump
hondata...
the previous tuner made 271@15psi....-jotech-
i think tony said that his intercooler is **** because the temp was like 130degrees....im not sure tho somewhere around there....
tony1 is a good tuner he tuned my ****
i just wanna know whats wrong with my friends setup?
any help would be appreciated
Old Sep 11, 2005 | 09:40 AM
B20TDC2's Avatar
Default Re: just got retune...whats wrong? (boosted2cam)
intake temps are kind of high . mine only get that high at idle in the middle of the day(in texas heat)
Old Sep 11, 2005 | 09:47 AM
TurboTegB18c's Avatar
Default Re: just got retune...whats wrong? (B20TDC2)
I would have to say the low compression and intercooler is what's hurting you.
Old Sep 11, 2005 | 09:53 AM
tony n.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20TDC2 &raquo;</TD></TR><TR><TD CLASS="quote">intake temps are kind of high . mine only get that high at idle in the middle of the day(in texas heat)</TD></TR></TABLE>
yeah i think so too...i got my car retune for better gas milege...he said my air temp was like at 101 i think it was like 90 outside im not sure about the temps tho but if it sounds right then lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTegB18c &raquo;</TD></TR><TR><TD CLASS="quote">I would have to say the low compression and intercooler is what's hurting you. </TD></TR></TABLE>
yeah thats what tony said
Old Sep 11, 2005 | 09:54 AM
alpha's Avatar
Has this motor's compression been checked? Leakdown?
Old Sep 11, 2005 | 10:06 AM
tony n.'s Avatar
Default Re: just got retune...whats wrong? (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">Has this motor's compression been checked? Leakdown?</TD></TR></TABLE>
i dont think it has been checked...how low is too low on a 8:1 compression?
the car was tune by jotech and made 271 but the car drove like ****...kept shutin off...that was like 4months ago or so then he just got retune by tony1 yesterday
Old Sep 11, 2005 | 10:39 AM
ATS*Mark's Avatar
OG triple OG
kept shutting off?
why 8:1 comp? thats awfully low.
Old Sep 11, 2005 | 10:54 AM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted2cam &raquo;</TD></TR><TR><TD CLASS="quote">
the car was tune by jotech and made 271 but the car drove like ****...kept shutin off...that was like 4months ago or so then he just got retune by tony1 yesterday</TD></TR></TABLE>
I would check it to rule that out. Not just that but perform a leakdown as well. Compression should check out between 150PSI - 170PSI. No more than 10PSI variance between cylinders. Yes the compression is very low but I think something mechanical is wrong. And I am sure the final static compression a little more than 8:1.
Old Sep 11, 2005 | 05:10 PM
tony n.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">kept shutting off?
why 8:1 comp? thats awfully low.</TD></TR></TABLE>
lol thats what everyone else said to him
I would check it to rule that out. Not just that but perform a leakdown as well. Compression should check out between 150PSI - 170PSI. No more than 10PSI variance between cylinders. Yes the compression is very low but I think something mechanical is wrong. And I am sure the final static compression a little more than 8:1.</TD></TR></TABLE>
yeah ill go check it for him...
thx for all the help
huntarrr
Dec 22, 2005 09:28 AM
chrisgottigsr
Sep 24, 2005 02:44 PM
a1320addict
Oct 10, 2004 11:09 AM
Spooled1.6L
Feb 15, 2004 02:38 AM
99B16Si
Nov 19, 2003 09:51 PM
