Just did a blockguard today..Help..?
Old May 3, 2003 | 06:16 PM
B18PoweredCivic's Avatar
Default Just did a blockguard today..Help..?
It is an AC Autotechnic blockguard/sleeve saver. I put it on a b17 bottom I have...Was it supposed to fit right in?...I had to do some grinding and really hammer that sucker in there...Its only about a 1/2 inch in...Is that good?...Or should it go all the way to the bottom?...Thanks
Old May 3, 2003 | 06:19 PM
94TealGSR's Avatar
Default Re: Just did a blockguard today..Help..? (B18PoweredCivic)
Ack! You're supposed to read up on how to install these things before you install them.
You should:
Drop it in there
Grind it down till it drops in
You shouldn't:
Hammer or force it in
If I were you I would get the block honed to make sure that yout cylinder walls aren't warped.
Old May 3, 2003 | 06:24 PM
Default Re: Just did a blockguard today..Help..? (94TealGSR)
DARN IT!!!...Lucky its just some little b17 block i have laying around...Should it drop in all the way?
Old May 3, 2003 | 06:42 PM
InfamousRS's Avatar
I HIGHLY suggest you get a bore and hone done on your block before you use it. By hammering it in you were likely to warp and distort the sleeves somewhat...
Old May 3, 2003 | 06:47 PM
TeStUdO's Avatar
yeah dude, your supposed to take a dremel to the blockgaurd to make it fit. it should slip in without hammering. the sleeves are probably egg shaped now
Old May 3, 2003 | 09:34 PM
BlueSi2k's Avatar
Default Re: (00si5)
and its supposed to stay at the top of the bore dont make it go all the way down. Grind it till it drops in and stays near the top.
Old May 3, 2003 | 09:38 PM
lazerus's Avatar
Default Re: (BlueSi2k)
Always read instructions!
(it tends to help things out a bit)
Masterl1nk
Engine Machining & Assembly
Apr 25, 2017 12:31 PM
95gsrturbo
Oct 9, 2010 04:55 PM
FMIDRC Racer
Feb 14, 2005 11:48 AM
Aeka GSR
Sep 19, 2003 11:53 PM
TurboSohc
Mar 20, 2003 08:38 PM
