just because its apexi
Old Jun 14, 2002 | 12:20 AM
ILOVEGIRLS's Avatar
Default just because its apexi
just because its an apexi intercooler, is it that much better than the spearco with the same dimensions? " silvia size BTW" its (19.7"L X 9.33"H X 2.7"W)
Old Jun 14, 2002 | 02:32 AM
boostedhb's Avatar
Default Re: just because its apexi (ILOVEGIRLS)
No I use a spearco. And I've had no problems with it. I think it's just the Name thing. It should be the same thing. All fmic basically do the ame thing. Besides save your money I know the spearco is alot cheaper.
Old Jun 14, 2002 | 03:17 AM
inspyral's Avatar
Default Re: just because its apexi (boostedhb)
I have a Spearco, and I like it, but the A'PEXi cores have the nice tapered endtanks and sweet delta fins...
Old Jun 14, 2002 | 03:46 AM
BlueShadow's Avatar
it could be *just* a name thing or maybe the Apexi FMIC are more efficient then the Spearco. Either way i'm sure there are more differences than just the name and prices.
Old Jun 14, 2002 | 04:06 AM
ninesecrx's Avatar
Default Re: just because its apexi (BlueShadow)
There actually is a lot of differences in these 2 intercoolers. Sprearco is a bar and plate style and apex is tube and fin style. They both have their ups and downs but either way...you cant go wrong. Id go with which ever is cheaper cause they both are great at getting the job done......Mike
Old Jun 14, 2002 | 05:44 AM
turbo Si's Avatar
Default Re: just because its apexi (ninesecrx)
A friend of mine just sold his brand new silvia core for a Spearco like mine (24x6.5x3). Seem's mine flowed more CFM. I think Apexi's looks great although I think it's more name than anything else!
Old Jun 14, 2002 | 05:56 AM
int3gra's Avatar
Default Re: just because its apexi (turbo Si)
I would like to quote FFgeoff if i may:
"One thing many people think when they see the Apex'i core is that its really cool... well thats because it looks really cool. It is actually fairly inefficient, but looks AWESOME. The Apex'i GT-R core flows poorly for its size. The Spearcos are the best bar and plate cores out there.
The difference between bar and plate is that the bar and plate style's core flow tubes look like the front of the IC with the zig-zag lines filling it up. The extruded cores have the small ribs where it touches the side (only place where heat transfer occurs) and allows the air to blow freely through. As a result, there is a lower pressure drop, and the same amount of heat is removed."
Old Jun 22, 2002 | 10:26 AM
ILOVEGIRLS's Avatar
Default Re: just because its apexi (int3gra)
where can u get them pressure tested?
Old Jun 22, 2002 | 06:30 PM
turbotypeR@SPEC's Avatar
25 Year Member
i went from a spearco to a apexi and it made a huge difference.it spools much faster and makes about 50 more whp.i think the fact that it made about 10 more pounds of boost after the install shows pretty much how much better it flows.
Old Jun 28, 2002 | 05:33 PM
ILOVEGIRLS's Avatar
Default Re: just because its apexi (turbotypeR)
nice. btw, do u have pics? im about to pic mine up this weekend if i have time. do u think 750 is a good price?
Old Jun 28, 2002 | 05:46 PM
95TurboLude's Avatar
Did you switch to the bigger Silvia core or the smaller one? I have a slightly banged up Silvia Apex intercooler that I'm considering using on my turbo Lude.
Old Jun 28, 2002 | 07:11 PM
25 Year Member
Default Re: just because its apexi (95TurboLude)
i used the gtr core.it is larger than the silvia core
ninesecteg
Jan 6, 2004 12:59 AM
ninesecteg
Dec 30, 2003 07:26 PM
DubyaAye
Mar 18, 2003 01:28 PM
H22TurboNos
Jan 12, 2003 06:12 PM
ILOVEGIRLS
Feb 13, 2002 02:11 PM
