jumpy throttle
Old Sep 13, 2003 | 12:47 PM
Frcfedintegra's Avatar
Default jumpy throttle
ive got a 94 integra ls with a turbonetics t3/t4 turbo and drag 3 manifold and safc hac. im having a problem with the throttle. when im trying to go at the same speed with out decelerating or accelerating, the car jerks like the throttle response it to touchy almost. i have plenty of fuel across the board. any thoughts?? the only thing i can think of is the throttle cable is to tight.?
Old Sep 13, 2003 | 01:11 PM
tegmech's Avatar
what fuel system are you using?
Old Sep 13, 2003 | 01:18 PM
raene's Avatar
Default Re: jumpy throttle (CivlizdSir)
I had that problem when my TPS was out of adjustment... fiddled with it and cured the problem
Old Sep 13, 2003 | 05:54 PM
Default Re: jumpy throttle (raene)
how did you fix it? im using rc 440 injectors and a walboro fuel pump and the safc hac to control the fuel curve. im running 12 psi and was dyno turned and put down 284 hp. but the jumpyness is really shitty. need some more advice on how to get rid of it.
Old Sep 13, 2003 | 06:37 PM
Lei Siew Long's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivlizdSir &raquo;</TD></TR><TR><TD CLASS="quote">how did you fix it? im using rc 440 injectors and a walboro fuel pump and the safc hac to control the fuel curve. im running 12 psi and was dyno turned and put down 284 hp. but the jumpyness is really shitty. need some more advice on how to get rid of it.</TD></TR></TABLE>
to adjust the TPS, take off the throttle body, slot the screws that hold down the TPS and adjust with a voltmeter.
what i did was, i stuck a sewing needle through the middle wire of the TPS harness and measured the voltage with a multi-meter. 0.5v Closed throttle and 4.5v+ WOT.
Old Sep 13, 2003 | 06:41 PM
raene's Avatar
Default Re: jumpy throttle (Hatch4urSnatch)
Sewing needle, good idea I actually removed the clip cover itself, stuck the wires on the TPS and then measured them that way. Your way's so much better!
Old Sep 13, 2003 | 07:20 PM
thank you
Old Sep 14, 2003 | 05:04 AM
ill try it today. hopefully it works. thanks guys
donivan_p
Engine Management and Tuning
Aug 19, 2014 09:18 AM
cadeMFjohnson
Aug 5, 2009 12:57 AM
hybridtheory4303
14
Apr 17, 2007 09:54 PM
SIRteggy
May 16, 2006 07:02 PM
turboteg2nv
Nov 28, 2005 10:29 PM
