jumped timing??? Please Look!!!
Old Aug 15, 2003 | 07:03 PM
VisualAutoMotoring's Avatar
Default jumped timing??? Please Look!!!
what is an easy way of telling if you have jumped timing or not....the car ran fine 2 days ago and i try starting it up today, and it sounds like its running on 2 cylinders, wont keep idle, and if i keep it rev'ed, it sounds like a lawnmower...
there are Skunk2 cam gears installed but I cant tell if the dots on the tooth end are marks for TDC....
PLEASE ANY HELP WOULD BE APPRECIATED!!!
Old Aug 15, 2003 | 07:05 PM
hoya_10fintec's Avatar
Default Re: jumped timing??? Please Look!!! (PRojectSi2)
any codes?
Old Aug 15, 2003 | 07:08 PM
Default Re: jumped timing??? Please Look!!! (hoya_10fintec)
nope no codes...like i stated, the car was started 2 days ago and was fine....and i decided to start it again today but wont stay and sounds like S*!t
Old Aug 15, 2003 | 08:35 PM
ScrapinSi's Avatar
put cylinder 1 at TDC and pull the valve cover... if the gears aren't at the top they are out of timing
Old Aug 15, 2003 | 08:40 PM
TurBoTeG's Avatar
the dot on the tooth, just above the degree lines on the gear is what you want pointed straight up
Old Aug 16, 2003 | 12:14 AM
the-anti-crack's Avatar
Default Re: (TurBoTeG)
put the motor at TDC....if everything lines up you are ok.
Old Aug 16, 2003 | 09:57 AM
Default Re: (the-anti-crack)
fixed!!! damn adjustable cam gears slipped....freaking crap!! thanks for the help!!!!
Old Aug 16, 2003 | 10:12 AM
SuperTeg95's Avatar
Default Re: (PRojectSi2)
Same thing happened to a friend of mine. The gears don't come tight, so ya gotta check them before you put them on. Glad you got it fixed.
Old Aug 16, 2003 | 01:46 PM
danl's Avatar
Banned
Default Re: (SuperTeg95)
Thats a great way to bend a valve
9hatch2
Nov 17, 2005 12:18 PM
elusive123
Dec 31, 2004 02:00 PM
Pengo
Jul 27, 2002 12:14 PM
