JRSC rotor question
Old Mar 2, 2006 | 06:54 PM
Speed--Freak's Avatar
Modified by Speed--Freak at 3:03 PM 6/6/2007
Old Mar 2, 2006 | 11:13 PM
Modified by Speed--Freak at 3:04 PM 6/6/2007
Old Mar 5, 2006 | 11:09 AM
Gojira D.O.T's Avatar
you can remove the coating with no adverse affects,its a teflon heat coating that they didnt even use on the old sc kits,my first sohc sc didnt have it and i bought it brand new
Old Mar 5, 2006 | 02:01 PM
sc4dr's Avatar
Default Re: (Gojira D.O.T)
You can remove the coating, but it wont be quite as efficient. The clearences will be greater, and "lubracicity" will be lower. Run it for a while with the blades the way they are, until you get the money to rebuild it
Old Mar 6, 2006 | 05:54 PM
HYREV2NR's Avatar
My rotors are chipped a bit. I had to replace the rotor assymbly w/ 1 from another charger I had cause the bearings were chattering. I put the SC black together & there was no change in boost level or the way it drove. If it does make a difference I think U would only find very small imfrations on a dyno. Don't worry about it & just let it ride.
Old Mar 8, 2006 | 11:11 PM
HYREV2NR
Aug 24, 2004 04:50 PM
HYREV2NR
May 1, 2004 08:26 AM
TodaTeg
Jun 6, 2003 12:29 PM
Captain Save-a-Hoe
Feb 13, 2003 07:07 AM
