JRSC Fuel Setup...
Old Oct 16, 2002 | 04:56 AM
TGUNNER's Avatar
Default JRSC Fuel Setup...
AEM fuel rail and FPR Walbro 255lph fuel pump.. I think Im going to go with RC 310 injectors(Is this a good Idea??).. Can I bypass the JR FMU and just use the AEM FPR?? The AEm FPR has a rise rate of 1:1.. or should i go with a Cartech FMU?? (Ive heard bad things about the JR FMU).. This is going to be on a 2K GSR at around 10lbs of boost via boost upgrade and crv crank pully.. Also going to be using a MSD 6btm... WHat do you think of this setup??? any input would be very helpful!! thanks
Old Oct 16, 2002 | 05:01 AM
B18Flip's Avatar
Default Re: JRSC Fuel Setup... (TGUNNER)
Bump
I'm curious too, but i'm thinking of going w/ an smc w/ larger injectors for my set up.
Old Oct 16, 2002 | 05:24 AM
Silverbeast's Avatar
For the money, get the Aeromotive FPR. The Jackson FMU does have a diaphram and gets stuck frequently. The 310's are fine for your set up. Unless you have some sort of standalone i would use the JR Map mod.
Old Oct 16, 2002 | 05:44 AM
TGUNNER's Avatar
Default Re: JRSC Fuel Setup... (HoustonSi)
the JR FMU has A 5:1 rise rate... Wich may be over kill i know you cant reduce that... You think 1:1 on the AEM FPR is too little?? And where can i come across an aeromotive FPR and how much are they?? thanks for the reply..
Old Oct 16, 2002 | 06:09 AM
you can pick up the aeromotive at http://www.jegs.com
look at
http://www.jegs.com/cgi-bin/ncommerc...50&prmenbr=361
thats the one i have. I think that the Jackson and that whole allen wrench screw thing blows, i had 3 get stuck on my car.
The AEM is fine, i dont remember how much the AEM is off hand, but i think for like 20.00 for the Aeromotive is a lot better.
I would think about the JR mad mod. it helps you lower that static fuel pressure and tip in detanation.
Old Oct 16, 2002 | 06:15 AM
TGUNNER's Avatar
thanks for the info... I already have the AEM FPR.. if that is not good enough i will try your suggestion.. Has anyone had any experience with water injection on the JRSC?? if so post your comments.. I was thinking about htis too because I know the JRSC runs hot at hight boost..
Old Oct 16, 2002 | 06:21 AM
I'm also running the JR/Aquamist kit. It does work well to cool intake temps, try the Hondata gasket as well. It helped my 10psi set up before i decided to run 14.
http://www.silverbeast.com
Look at the black motor...thats my new project.
Old Oct 16, 2002 | 06:27 AM
Rory Breaker's Avatar
The Cartech will be $200, the AEM FPR and Fuel rail(which btw isnt necessary) are another $275 together, plus the injectors...
You may as well go with a Hondata/DSM setup.
Old Oct 16, 2002 | 06:34 AM
TGUNNER's Avatar
NIce pics!! make me jelous!! WHat do you mean honda gasket?? And your running 14lbs?? i was think of that too.. but can the SC handle it?? thanks once again
Old Oct 16, 2002 | 07:19 AM
B18Flip's Avatar
Hondata makes a an intake manifold gasket which is supposed to decrease heat soak.
Old Oct 16, 2002 | 09:26 AM
i2un's Avatar
1) No you can't just bypass the FMU and just use the Aem regulator....the 310 injectors are too small that's why people use 440's with standalones or SMC's or the S-AFC.
2) 310's + Cartech + Aem regulator is a proven set-up. 310's so you don't run lean. Cartech, to lower the rise rate...so you don't run ungodly rich and Aem regulator to lower your idle fuel pressures for that intank fuel pump.
3) If you have the money a tuned standalone is way better than any of the above.
4) If you need a Cartech 2025 (for supercharged appz.). I can sell you a new one for $180 shipped.... If you check the Cartech website I believe they sell them for $250 not including, tax + shipping. Let me know by email if your interested.
[Modified by i2un, 6:27 PM 10/16/2002]
Old Oct 16, 2002 | 10:02 AM
B18Flip's Avatar
Default Re: JRSC Fuel Setup... (i2un)
Good info thanks man!
Old Oct 16, 2002 | 11:35 AM
TGUNNER's Avatar
Yeah good information thanks.. You got mail....
Old Oct 16, 2002 | 11:51 AM
MikeMAN's Avatar
wow! i was thinkin' about a JRSC for my B16, and this made thinking about fuel management that much easier!! thanks guys!
for the honda-techers
Spooler978
Apr 9, 2012 08:10 AM
JDC2TypeR
Aug 25, 2007 11:32 AM
flarinpnoi
Mar 3, 2004 08:04 PM
integra95
Sep 25, 2003 04:37 PM
Big James
Oct 18, 2001 06:39 PM
