JRSC on a EF with b16a
Old Dec 17, 2001 | 03:23 PM
iwhichisme's Avatar
Default JRSC on a EF with b16a
Does anyone know or have a ef series car with a b16 and a JRSC. Will it fit?, if so, what kind of numbers can you expect to get out of it?
Old Dec 17, 2001 | 03:25 PM
falcongsr's Avatar
What is this crap?
Default Re: JRSC on a EF with b16a (iwhichisme)
ask Jim at wheelking@webtv.net for JRSC stuff. he's really helpful.
Old Dec 17, 2001 | 03:28 PM
brian b's Avatar
New User
it all depends on whats in back of the intake manifold.. what manifold do you have on the car right now? if its similar to the 00 si manifold in length/height then you need about an inch past the manifold, and lots of space under it to house the blower.. if you can get any pics of your car without the intake manifold on it, it would be alot easier to tell for sure.. i think the only honda/acuras that cant fit one would be the 92ish integras because of the brake master being in the middle instead of off to the side..
btw, im selling a JRSC for a b16a (from a 00si) $1850. the blower was just remanufactured (0 miles!) by magnusen (due to a gear failure) with new rotors, bearings and gears
Old Dec 17, 2001 | 04:16 PM
boosted hybrid's Avatar
I have seen b16a EF with the JRSC, there were no fitment problems at all. The car really seemed to haul some ***. This was at street races, so I cant really give you a time slip, but he was hanging with 12sec car...he was on slicks.
Old Dec 17, 2001 | 06:07 PM
Blown90hatcH's Avatar
Default Re: JRSC on a EF with b16a (boosted hybrid)
I have done both a Gsr in an EF with the JR and a B16a into an Ef with the JR. Both times I have used the HCP Engineering mount kit. http://www.hcpengineering.com
There was about 3"s to clear on the firewall and about 1.5" on the clearance of the master cylinder. Talking to Locash a while back, I know that with the Hasport kit, the blower didnt clear the master cylinder and booster. I dont know what they have done since then. Brian should know that answer though. My car at 13psi ran 12.7s on street tires, spinning most of the way down the track. It put around 300 whp. On the b16a into the ef, again it cleared fine and put down 185 whp. Both of these cars were with just header and cheap exhaust.
Jason
GZNDEG
May 16, 2016 04:39 AM
shahriar35
Apr 21, 2016 03:20 PM
coreyBWA
Sep 14, 2013 10:44 AM
rb240z71
Feb 1, 2009 10:21 PM
riot
29
Mar 13, 2003 09:26 PM
