JRSC destall question.........
Old Nov 22, 2003 | 05:54 AM
siis2fast's Avatar
Default JRSC destall question.........
what size hex key do you need in order to remove the IM from the blower itself? There 2 diffrent sizes, one is pretty big, like a 8mm or something. but i have to go buy them on a socket, and id just like to get the right size the first time
Old Nov 22, 2003 | 07:32 AM
keebler65's Avatar
Default Re: JRSC destall question......... (siis2fast)
those are 6mm bolts. the instructions (mine anyways) said 8mm on JR. however there is an 8mm hex bolt on the bracket i belive. but the blower bolts are 6mm. you mentioned buying a socket....just make sure the socket's outside diameter isnt too large to fit through the access holes on the manifold. i just ended up using a long allen wrench.
good luck
Projekt_2nr
Dec 22, 2016 03:52 PM
Ldo
Feb 27, 2010 09:20 PM
PianoMan
Welding / Fabrication
12
May 8, 2007 09:15 PM
G.
Oct 30, 2005 01:09 PM
HybridKOOP
Jul 9, 2002 07:57 AM
