JRSC and shearing bolts????
Old Oct 28, 2005 | 11:36 PM
G.'s Avatar
G.
Default JRSC and shearing bolts????
Hey folks.
I have a UK EP3 Type-R, that has a Jackson Racing Supercharger fitted. Now I am just running the street (4psi) kit. Around 8 months after it was fitted. Two of the bolts that mount the charger onto the inlet side of the block sheared off leaving the ends of the bolts in. My tuner managed to remove these and fit upgraded bolts. Now 6 months further on the same two bolts have sheared again!
They are the top and bottom bolts on the far right as you look.
The car is never tracked and driven with mechanical sympathy allways (with that power you do not need to be brutal )
Anyhoo, I was just wondering if any of you folks with chargers on K20's had suffered the same at all.
Thanks for any help.
G.
Old Oct 29, 2005 | 07:32 PM
EnzoSpeed's Avatar
Default Re: JRSC and shearing bolts???? (G.)
Either fabricate a brace for the charger, or try some grade 13 hardware.
Old Oct 29, 2005 | 07:36 PM
hybrid_KJ's Avatar
Default Re: JRSC and shearing bolts???? (EnzoSpeed)
We recently lost the bolts in our charger 00 gsr it ate up the charger a bit but was reapairable.
Old Oct 29, 2005 | 07:51 PM
EnzoSpeed's Avatar
Default Re: JRSC and shearing bolts???? (hybrid_KJ)
It's probably because the M60 units are really heavy. They should come factory braced from JR.
Old Oct 30, 2005 | 03:08 AM
G.'s Avatar
G.
Thanks for the help guys, I was thinking of some kind of brace on the right hand side. The bolts I am using have 8.8 stamped on the top? I guess that is not up to the job
Old Oct 30, 2005 | 07:41 AM
EnzoSpeed's Avatar
8.8 is child's play . Look for the hardware with the flat black finish - it's rated at 12.9.
Old Oct 30, 2005 | 12:53 PM
Tad's Avatar
Tad
i'm just curious,
what do you mean by "sheared off" exactly?
Old Oct 30, 2005 | 01:09 PM
EnzoSpeed's Avatar
Default Re: JRSC and shearing bolts???? (Tad)
Broke.
Although another issue that arises is that the aluminum threads rip out of the charger. DON'T overtorque the bolts or you'll have to helicoil the threads.
dkrex001
Oct 15, 2008 06:24 AM
functionFiRst
Mar 2, 2002 10:44 AM
