JRSC B16A - How much boost?
Old Jun 10, 2003 | 11:44 AM
motore's Avatar
Default JRSC B16A - How much boost?
Hey Guys,
I have an CRX with a B16A - Charged (JRSC)
I was running about 7lbs
and wanted to go higher I put on a CRV Crank Pulley and got as high as 14-15lbs.
I really dont wanna put Pistons and rods cuz Im gonna have to pay alot of $$.
How high on a tuned Hondata JRSC B16A stock internals, do you guys think?
And if anybody knows
What pulley will get me about 10-11 lbs. (no higher)
I was getting 7lbs on a stock b16a crank pulley
Let me know
Thanx
Old Jun 10, 2003 | 12:01 PM
YumVTEC's Avatar
Default Re: JRSC B16A - How much boost? (motore)
with good tuning you should be able to run more than what you are running now, but why tempt fate? Get your bottom end sleeved and built.
Old Jun 10, 2003 | 01:14 PM
motore's Avatar
Default Re: JRSC B16A - How much boost? (YumVTEC)
Yumvtec are you saying I could even run higher than 14-15
cuz thats what its at right now.
Does anyone know what pulley will make 10-11 lbs?
Old Jun 10, 2003 | 01:16 PM
Muad'Dib's Avatar
Corr Performance Pilot
that is a lot of heat that you're introducing into that engine with that crank pulley. once the heat goes to a certain point... all that boost will turn into your worst enenmy. the Endyn Stepper pulley will probably get your the PSI that you're looking for if you have the 8 PSI pulley already on the blower.
Old Jun 10, 2003 | 01:26 PM
motore's Avatar
Also I have many things to lower the engine temp like:
Oil Cooler
Lower Thermostat
Hondata Intake Gasket
That should help me out
Old Jun 10, 2003 | 01:31 PM
jdmWONG's Avatar
i used to have the same setup as you in my crx, i was using the endyne stepper pully and i saw about 10 lbs of boost on my bone stock b16a. never had a problem. i would not suggest running the crv pully with a stock blower. the supercharger is not efficient and is just making more heat, which you do not want.
get a stepper pully and make sure you have enough feul and you will be fine.
Old Jun 10, 2003 | 08:23 PM
motore's Avatar
Default Re: JRSC B16A - How much boost? (TURBOEF8)
Do you guy know how much this pulley is?
Old Jun 11, 2003 | 08:19 AM
Muad'Dib's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBOEF8 &raquo;</TD></TR><TR><TD CLASS="quote"> i would not suggest running the crv pully with a stock blower. the supercharger is not efficient and is just making more heat, which you do not want.
get a stepper pully and make sure you have enough feul and you will be fine. </TD></TR></TABLE>
i have the CRV crank pulley with my 8 psi nose pulley and from what I've seen..... i'm getting less heat than some people with a regular nose pulley and crv crank pulley.
Old Jun 12, 2003 | 09:14 PM
motore's Avatar
Default Re: JRSC B16A - How much boost? (MouhadIb)
Im getting the LS integra pulley will that help
hopefully around ten????
Old Jun 12, 2003 | 11:05 PM
Muad'Dib's Avatar
i've not personally heard anyone using that pulley.
Old Jun 13, 2003 | 09:10 AM
98civicguy's Avatar
Default Re: (MouhadIb)
get the 5-rib pulley set from LHT Performance. get a hold of john from this board, his screen name is (CRVRX).
Old Jun 13, 2003 | 05:03 PM
escocrx's Avatar
Default Re:
what charger? M45? M62?
If ethier even the bigger M62 isnt real efficient above 11psi. But this is just what a tuner says in town. He says it heatsoaks and actually over works the charger. But dont quote me on that. As I'm going by his word, not my knowledge.
Old Jun 13, 2003 | 06:39 PM
motore's Avatar
Default Re: Re: (escocrx)
sir is m42
Type R is M45
H22a is M62
I have the R charger
Hope fully this LS Pulley works.
Old Jun 14, 2003 | 06:34 AM
stevecockrill's Avatar
Default Re: Re: (motore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motore &raquo;</TD></TR><TR><TD CLASS="quote">sir is m42
Type R is M45
H22a is M62
Hope fully this LS Pulley works.</TD></TR></TABLE>
Look here - http://jacksonracing.com/pages/components.html, then click on the appropriate vehicle. For example -
99-00 Civic Si (B16A2, DOHC VTEC) - 051-265 S/C GEN3 M62CCW 4.2-4R 1
97-01 Integra Type R (B18C5, DOHC VTEC) - 051-265 S/C GEN3 M62CCW 4.2-4R 1
97-0 Prelude SH (H22A, DOHC VTEC) - 051-605 S/C GEN3 M62CCW 3.4-6R 1
The DOHC VTEC engines use the M62 blower.
SOHC and DOHC non-VTEC engines typically use the M45 blower
HTH!!
Steve
ty521825
Jun 18, 2009 12:22 AM
gosu08
Apr 27, 2009 07:49 AM
mrx
Jul 12, 2006 06:30 AM
TheSwift1
Oct 17, 2004 06:30 PM
suprchrg95
May 17, 2004 01:10 PM
