JRSC and 11:1 compression
Old Aug 16, 2003 | 03:29 PM
1strdko's Avatar
Default JRSC and 11:1 compression
first off I had a **** load of problems with my JG "pro series" block on a lsVtec conversion. I am scraping it and buying a new Ls block.
The ls block has 11:1 compression. Will 8-10 psi be too much with a hondata s200? I am concerned that the compression will be too high and need ideas on which Commetic head gasket will lower the compression. I am also curious if the Golden Eagle block gaurd and LsVtec oil kit are a good Idea. I need an oil line for this where would I find one?
Thanks for your help!!!!!!!!!!
Old Aug 16, 2003 | 03:51 PM
tegrakid's Avatar
Default Re: JRSC and 11:1 compression (1strdko)
i know a guy here in atlanta, Ga who has a b16 with a jrsc with high compression pistons sadly it made 207whp and ran a 13.7 in the 1/4 when he had a bone stock b16 it ran 12.9 with upgrade pulley
Old Aug 16, 2003 | 08:38 PM
1strdko's Avatar
Default Re: JRSC and 11:1 compression (tegrakid)
I am curious if 11:1 is asking for a blown ring?
Any turbo cars running 11:1 or higher compression?
Old Aug 16, 2003 | 09:08 PM
keebler65's Avatar
thats really high....i assume you'll be running race gas?
Old Aug 18, 2003 | 09:14 AM
1strdko's Avatar
Default Re: JRSC and 11:1 compression (keebler65)
No just 91 octane. Will this be safe of should I go back to the 6 psi pulley?
Old Aug 18, 2003 | 09:32 AM
TOFU.man's Avatar
i think you need to stick with 6psi and get proper tuning.
cycleguy88
Sep 11, 2006 02:12 AM
untitled
Jan 6, 2004 07:48 PM
flatline
Apr 13, 2003 08:49 PM
sicilian2k1
Nov 15, 2001 11:42 AM
