JRCS and hondata problems
Old Feb 23, 2004 | 06:08 AM
Paluce's Avatar
Default JRSC and hondata problems
My question is,,, is their some kind of limp mode that the Hondata has if it's not getting info from the chip?
Here's the problem...
Saterday morning I went to start the car and it had a check engine light and ran like poop. I pulled the codes and the check engine light was solid, but the ABS light was flashing me codes??? non of them were honda codes (17, 83.. wierd ones) plugged the connecter back in and the car ran fine.
that same day while I was driving, the check engine light flicked on for like 1/2 a sec. then went away. Then 10 min later, it came on at a light and the car stalled??? I started it back up and drove to dinner. THe car was running full rich and in open loop all the time (Autometer A/F gauge showed that). THen I drove back to my grandperents for 5min same condition. When I started the car to leave, no engine light??? ran perfectly. THis has happened a couple times in the last few days. The hondata was installed only a week ago.
Sorry for the long story, but that's my problem.... Any ideas?
Modified by Paluce at 4:18 PM 2/23/2004
Old Feb 23, 2004 | 09:40 AM
Paluce's Avatar
Default Re: JRSC and hondata problems (Paluce)
anyone???
Old Feb 24, 2004 | 06:26 AM
Paluce's Avatar
anyone have an idea??
I think it could be the cable from the hondata to the ECU.. but I'm new to hondata, and I still don't know anything about this limp mode. is it safe to drive in limp mode?
Old Feb 24, 2004 | 07:08 AM
RacerXI's Avatar
Check all your connections. It sounds like you have a loose one somewhere.
Old Feb 24, 2004 | 08:24 AM
Spunkster's Avatar
Definately a loose wire some where.
Old Feb 24, 2004 | 08:55 AM
Paluce's Avatar
I'll check my connections and post later.
Thanks,
Old Feb 24, 2004 | 10:45 AM
Mase's Avatar
check the soldering of the eprom socket
Old Mar 4, 2004 | 07:09 AM
Paluce's Avatar
I got the chip reburned yesterday, and for the first time in 10 days I havn't got a check engine light. Although, last time I went 3 days before the first light popped up. we'll see......
Old Mar 4, 2004 | 08:20 AM
Jefnes's Avatar
Solid CE light means blue box/chip comm error....
If the CE light doesn't go out ~10 sec (when fuel pump stops) after
key up (not start), its a comm error.
Could be corrupt tune, blue box, lose wire....
Jeffrey Atwood
Old Mar 8, 2004 | 05:11 AM
Paluce's Avatar
Default Re: JRSC and hondata problems (Jefnes)
well so far after reburning the chip, I've gone 5 days without a CE light. Looks like the chip got a bad burn or something??? Is this common?
Thanks for all the input!
97_hatch
May 19, 2008 10:07 PM
Paluce
Oct 11, 2005 05:52 AM
tub_sephiroth
Apr 16, 2005 06:22 PM
martini
Apr 22, 2003 11:27 PM
