jdm gsr ecu chipable?
Old Dec 14, 2005 | 10:22 PM
gapergurlie_18's Avatar
Default jdm gsr ecu chipable?
Hi, I was reading somewhere that you cannot chip the jdm P72 ecu.
Is that true for all the plug and play thing chips (ie. Hondata, Neptune, crome, uberdata).
I have never heard of that before.... I believe that the p28 will work for me as well but i loose some things
Please clear this up for me HT
Old Dec 15, 2005 | 12:40 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: jdm gsr ecu chipable? (gapergurlie_18)
jdm ecu's use surface mount components from what i remember..
also, the only thing you will lose is the IAB control, but if you are running an aftermarket intake mani then it wont be a problem
Old Dec 15, 2005 | 03:01 AM
what is the difficulty of "surface mount".
would it be easier/better to get a p28 chiped ecu?
Old Dec 15, 2005 | 08:01 AM
Dee's Avatar
Dee
Default Re: (gapergurlie_18)
I ran Stage 4 boost and S200B Hondata's on my JDM P72 with no problems. I actually have an S200B P72 that needs a new home
Old Dec 15, 2005 | 08:37 AM
cobra2326's Avatar
Yes, it is chippable. IMO, the surface mount made the chipping process easier, with the exception of the TINY capacitors you have to install.
Check out http://www.pgmfi.org/twiki/bin...lCase, its for a JDM small case, but should be similar. Also, http://www.moates.net is where I got my chip kit, the kit costs $15 bucks and the burner is another $80, datalogging is $30 from there and comes with a USB cable. Not too hard, just be careful.
Old Dec 15, 2005 | 10:43 AM
blundar's Avatar
OBD1 JDM P72 manual is ok.
OBD1 JDM P72 auto is a weird hybrid design that isn't chippable.
Dool_Ohver_Hed_Cam
Oct 2, 2007 08:46 AM
B_radGSR
May 23, 2006 11:11 AM
bulori
Aug 17, 2004 11:14 AM
