JDL Mani
Old Mar 15, 2016 | 04:53 AM
GrantMC2's Avatar
Default JDL Mani
Just encase anyone wanted to see .. Mock of my JDL mini ram horn with GT2871r ..
Old Mar 15, 2016 | 04:54 AM
GrantMC2's Avatar
Default Re: JDL Mani
Only Q i have is that the ridge on the W/G is very very close to the protruding alloy on the block ( I think that is a water way there?)
Could i shave part of this alloy down? Or is it too thin?
Old Mar 15, 2016 | 05:33 AM
turbohatch96y7's Avatar
Jdl makes good stuff
Youre going to have to get a better pic of the wastegate and block area
Old Mar 15, 2016 | 11:03 AM
LightningTeg's Avatar
Community Builder
Nice piece of stainless right there!
Old Mar 15, 2016 | 12:21 PM
GrantMC2's Avatar
Old Mar 15, 2016 | 12:22 PM
GrantMC2's Avatar
Old Mar 15, 2016 | 12:23 PM
GrantMC2's Avatar
It's certainly close, but not touching. What do we think, enough of a gap?
Old Mar 15, 2016 | 01:37 PM
If i was in this situation
I would paint the block where the wastegate actuator is
Then run it for a few miles
Check to see if it hit the block at all.
I think youre fine
Old Mar 15, 2016 | 02:27 PM
GrantMC2's Avatar
Good idea turbohatch, cheers mate.
Old Mar 15, 2016 | 04:18 PM
Stopsign32v's Avatar
Loved
What are the specs on that turbo and what are your goals power wise?
Old Mar 15, 2016 | 11:32 PM
GrantMC2's Avatar
Gt2871r .64 ar. With the bigger inducer and exducer.
Looking for 300 bhp initially on the 7psi Spring with s little boost control. And looking to wind it up and go for 375-400 which I think will be the max of the turbo.
Old Mar 16, 2016 | 12:14 PM
Flr Power's Avatar
The turbo manifold will expand the more heat you give it. Expect to see significant change.
I would do the paint mark trick as turbohatch96y7 mentioned.
Old Mar 16, 2016 | 12:57 PM
Geis's Avatar
Took me way to long to spot that it's internally gated lol.
Looks clean
Old Mar 17, 2016 | 06:41 AM
GrantMC2's Avatar
Thanks for the input chaps!
Old Mar 17, 2016 | 08:37 AM
motoxxxman's Avatar
yes, but the angle of that expansion is down and out, bringing it further away from the block, not closer. I think he'll be ok. but it would be a good idea still to paint it and check after a bit of driving to see if it is touching at any time. it's close enough to the block that engine vibration alone could make it touch, but I doubt it. if it does touch, you could just use 2 exhaust mani gaskets, it will bring it out away from the block the same amount as the gasket is thick
Old Mar 17, 2016 | 08:40 AM
Turbo-LS's Avatar
I dont see a problem there. Let it eat
Old Mar 17, 2016 | 08:42 AM
GrantMC2's Avatar
Let it eat?
@motoxxxman yes mate, not a bad idea that with the gasket. Thanks for the input.
Old Mar 17, 2016 | 08:58 AM
I wouldnt use two gaskets
"Let it eat" means
If it hits the block let it make its own room lol
Old Mar 17, 2016 | 09:48 AM
GrantMC2's Avatar
"Let it eat" means
I like it!!!
Old Mar 17, 2016 | 03:11 PM
Turbo-LS's Avatar
Turn up the boost and make power. It prob won't rub and if it does it'll be very minimal
And wear its own clearance.
Old Mar 17, 2016 | 08:17 PM
motoxxxman's Avatar
lol. I usually mock or give crap to people who recommend hacked methods. But I sometimes do things like that too, depending. and the above suggestions are actually good ideas
Old Mar 18, 2016 | 02:25 AM
GrantMC2's Avatar
Thanks for the input people ..
I'll use the paint idea, to see whether it rubs ..
Now to see whether this turbo will actually make any power :-/
Old Mar 18, 2016 | 03:06 AM
Community Builder
Just gotta stack the boost man
Old Mar 18, 2016 | 04:18 AM
motoxxxman's Avatar
lol.
"how much boost you running?"
"all of it. unless there's a leak. then some of it"
JDM_COUPE
May 2, 2007 10:33 PM
sittin on GOLD
Mar 21, 2006 07:57 PM
edo
23
May 20, 2005 05:32 PM
Bbasso
Nov 29, 2003 11:06 AM
B18CXr
Apr 14, 2003 02:15 PM
