jackson supercharge gsr?
Old Mar 28, 2003 | 05:30 PM
white4drint's Avatar
Default jackson supercharge gsr?
I want to supercharge my 95 4dr gsr. I dont know how much the overall cost would be and what i need to do to my engine if i get the sc.
Old Mar 28, 2003 | 05:35 PM
ekb18c's Avatar
Default Re: jackson supercharge gsr? (white4drint)
Step 1- contact is jackson racing dealer for pricing
Step 2- contact a shop for install price.
Step 3- Start saving up for Hondata (Fuel management system)
If you are going to running around 7psi then there is nothing you need to do internally to the block.
I advise to get Hondata when you have enough money because you will gain tremdous power over the fmu and stock ecu.
Look at Hipemotorsports dyno numbers that he posted and notice the amt of hp he gained from doing hondata.
Step 4-Buy Hondata
Step 5-Get it tunned and enjoy the extra power and piece of mind.
HTH
Old Apr 3, 2003 | 05:41 PM
Tru Dynamix's Avatar
Default Re: jackson supercharge gsr? (ekb18c)
i was curious if u or anyone knew if adding a hondata to the low moderate boost levels will pass smog
Old Apr 3, 2003 | 07:01 PM
keebler65's Avatar
Default Re: jackson supercharge gsr? (Tru Dynamix)
from what i've *heard* the hondata usually has troubles passing smog, which is why hondata people often wire up the SMC for a temp fix so that they pass smog, then put the hondata back in. i dont know if that info helps you or not.
Old Apr 4, 2003 | 08:56 AM
Spunkster's Avatar
Default Re: jackson supercharge gsr? (keebler65)
I put my stock ECU and injectors in my car and wired the bypass valve open and FAILED miserabley, but passed the OBD2 ecu test. I then in the parking lot swapped in the obd1 p72, Hondata and 440cc injectors (10 minutes), waited in the line for 5 minutes and passed the smog test with less emissions than a fart.
The key was that they "only tests what fails".
Oh and I passed with the bypass valve in normal operation.
[Modified by Spunkster, 10:53 AM 4/4/2003]
fuel..
Engine Management and Tuning
Jan 8, 2012 08:20 PM
vactor
Midwest
Jun 24, 2009 07:15 PM
rustydusty1717
59
Dec 15, 2008 05:00 PM
phoenixheat_2002
Mar 18, 2008 05:39 PM
fatal lightning
Sep 13, 2005 10:57 PM
