J&S question(s)
Old Jan 10, 2003 | 07:25 AM
rjardy's Avatar
Default J&S question(s)
I was wondering if i can use my factory knock sensor and wire that into the J&S to get its readings? Or do i need an aftermarket unit (GM unit)
allso i have a dual monitor and need to know how to hook it up, there are two (2) hookups on the back, a small one and and a large one.
Thanks
Rob
Old Jan 10, 2003 | 07:31 AM
SoulSurfer's Avatar
Default Re: J&S question(s) (rjardy)
You need to trade me units.
Old Jan 10, 2003 | 07:33 AM
rjardy's Avatar
Default Re: J&S question(s) (LSDelSol)
no i like mine its new and improved
now help me or shutup!!!!
Rob
Old Jan 10, 2003 | 07:42 AM
rjardy's Avatar
bump
Old Jan 10, 2003 | 07:47 AM
SoulSurfer's Avatar
How are you going to bump something after 10 minutes? Hey mine's just the single monitor right?
Old Jan 10, 2003 | 08:24 AM
Farnsrocket's Avatar
Yes, the J&S uses your factory knock sensor....what car do you have?
The actual knock indicator/LED part of the dual monitor is connected by the wire with plugs on both ends. One end plugs into the back of the dual monitor and the other plugs into the front of the J&S unit.
The O2 sensor has a wire with a plug that goes into the back of the dual monitor and three wires on the other end that splice into your ecu O2 sensor signal wire and 2 grounds I think. I did not use this since I have an FJO LED display.
Old Jan 10, 2003 | 10:50 AM
rjardy's Avatar
Default Re: J&S question(s) (Farnsrocket)
its a 00 ex, yes they have knock sensors (some folks didnt think so)
Any place i can find out for sure about the wiring?
Rob
Old Jan 10, 2003 | 12:12 PM
rjardy's Avatar
bump please!
Old Jan 10, 2003 | 12:55 PM
JT's Avatar
JT
What Farnsrocket said is correct. The cable that has 3 wires should be connected as such -> bare wire to chassis ground, ground wire to O2 sensor ground, signal wire to O2 sensor wire (white).
Old Jan 10, 2003 | 07:40 PM
rjardy's Avatar
Default Re: J&S question(s) (JT)
coo thanks allot guys
rob
beginmyhonda
Jul 29, 2009 02:14 PM
nub_pwn
Nov 18, 2006 11:48 PM
ZaxEG
Oct 2, 2003 07:35 PM
