J&S dip switches/install...
Old Sep 26, 2002 | 02:10 PM
dustin's Avatar
Default J&S dip switches/install...
Is there a pdf or something somewhere that explains this?
Old Sep 26, 2002 | 02:22 PM
Farnsrocket's Avatar
Default Re: J&S dip switches/install... (dustin)
you have it's for the ultra, but it may have some of the same stuff
Old Sep 26, 2002 | 02:26 PM
dustin's Avatar
Default Re: J&S dip switches/install... (Farnsrocket)
Cool that helps ... the ultra has a 5 pin DIP switch and mine has 4 pin.. I wonder if it's just the first 4??
Old Sep 26, 2002 | 02:28 PM
Sonny's Avatar
This is my diagram for the Ultra Safeguard. Classic Safeguard is the same except that it doesn't have a VTEC wire. The yellow wire on the Classic Safeguard goes to the TPS signal (tap into the signal...don't cut the wire).
Switch 1 -> 10/20 deg of max retard (10 deg is down)
Switch 2 -> Retard All/Retard individual (start out with retard all - switch up)
Switch 3/4 -> Both should be up (instructions don't say why)
Sonny
[Modified by Sonny, 3:29 PM 9/26/2002]
Old Sep 26, 2002 | 02:33 PM
dustin's Avatar
Default Re: J&S dip switches/install... (Sonny)
Awesome, thanks Sonny
Old Sep 26, 2002 | 03:42 PM
ElectronMan's Avatar
I heard there were problems when the J&S installed with the Hondata. How do you fix it?
Also, I have a 99 Civic Si, can I tap into the stock knock sensor signal?
[Modified by ElectronMan, 12:44 AM 9/27/2002]
Old Sep 26, 2002 | 04:06 PM
Sonny's Avatar
Default Re: J&S dip switches/install... (ElectronMan)
It kills the tach with and OBD1 ECU installed in an OBD2 car via an adapter harness. To fix it, you need a 1k ohm 1/4 watt resistor between the ICM and power wires on the J&S harness (red + green). Just install the resistor on the plug. Works like a charm.
Sonny
Old Sep 26, 2002 | 04:08 PM
dustin's Avatar
We'll see how it acts with the AEM EMS
Old Sep 26, 2002 | 10:24 PM
dustin's Avatar
Ok I put the J&S in. I haven't driven the car but it starts so I guess it's fine. The little red light blinks as the motor runs... seems to be in sync with output to the ICM ?
Old Sep 27, 2002 | 07:33 AM
Nice, whats that silver box?
Old Sep 27, 2002 | 07:58 AM
falcongsr's Avatar
What is this crap?
yeah the wire you spliced was the ignition trigger to the ICM. the J&S just adds a slight timing delay to retard timing. if you have it retarding all 4 cylinders, then it adds the delay to 4 consecutive pulses. if you have it retarding individual cylinders, then it delays every 4th pulse. nifty.
Old Sep 27, 2002 | 08:41 AM
TurboedGSR's Avatar
seems like a diy wb
Old Sep 27, 2002 | 02:07 PM
dustin's Avatar
Default Re: J&S dip switches/install... (TurboedGSR)
Yep that's the wideband controller. I guess the thing is working. What should I start with for the sensitivity setting? I have it set about 10 o'clock...
Simple
13
Jan 10, 2004 07:57 AM
Want2race
Jan 14, 2003 12:51 PM
j0se
Nov 13, 2002 01:46 PM
Jeff_G
Sep 30, 2002 01:35 PM
