It's All Over... :'(
Driving on the highway.. was partial throttle prolly aroudn 5 grand or so. in boost... all of a sudden. car kinda hesitates and budges a bit then continues to run fine but jsut as that hesitation. OIL LIGHT. all of a sudden. engine is making the worse rattlnig/ticknig kinda nosie ever. I'm a ways from home. pull over to a stop.... pop hood.. everything looks fine.. check oil. oil level is fine.(I'm running normal setup. fitler on block. turbo feed off oil pressure sensor) so if oil level is fine. must have no oil rpessure or very little. I know it's fucked eitehr way. I'm pissed and don't care anymore and drive ti home keeping revs low at around 2000... get home. take oil feed lnie off turbo. turn the engien over and run it for a few secodns. shut it off. only a bit of oil came outta the feed line.... so I don't ahve oil pressure really what so ever. my conclusion is prolly my opil pump ate the dust and I spun a bearing... but the rattlnig type nosie is comnig more fromt he ehad so maybe I wrecked the head. but either way tog et to the oil pump. pretty much gotta take it out anwayys as it's not an easy task. UGH.. so depressed.
That sucks what was your setup what oil/filter were you using.
BTW I had a similat problem except it was my turbo that was making the noise boclked oil line, it was a piece of silicone.
hey i think i have the same problem as you except my car died on the freeway. i couldnt figure it out either. the next day we did a compression test and it was at a big fat 0. now i cant figure out whats wrong so we're just gonna intall my spare motor i had laying around. good thing i still kept that motor around. good luck to ya
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">Driving on the highway.. was partial throttle prolly aroudn 5 grand or so. in boost... all of a sudden. car kinda hesitates and budges a bit then continues to run fine but jsut as that hesitation. OIL LIGHT. all of a sudden. engine is making the worse rattlnig/ticknig kinda nosie ever.</TD></TR></TABLE>
you gave me flashbacks with that description! seriously, thats exactly what happen to my engine.
except for the fact that mine wasnt even CLOSE to running afterwards and i had 2 holes in my block..
good luck man, i know what youre going through... just try to keep your head up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> I know it's fucked eitehr way. I'm pissed and don't care anymore and drive ti home keeping revs low at around 2000... get home. take oil feed lnie off turbo. turn the engien over and run it for a few secodns. shut it off. only a bit of oil came outta the feed line.... so I don't ahve oil pressure really what so ever. my conclusion is prolly my opil pump ate the dust and I spun a bearing... but the rattlnig type nosie is comnig more fromt he ehad so maybe I wrecked the head. but either way tog et to the oil pump. pretty much gotta take it out anwayys as it's not an easy task. UGH.. so depressed.</TD></TR></TABLE>
you drove it home??? it could have just been the oil pump and/or a spun bearing. a HELL of alot cheaper to fix then the entire motor.
Guess we will never know now. goes to show were getting pissed gets you.
at the least you still had a good head. who knows now.
I feel you pain dude but damn.
i know that feeling very well
i have blown 4 engines
and let me tell ya
u are one lucky bastard
u are lucky ur block is still good and doesnt have 2 holes in it
spun bearings can be fixed
trown rods cant
count ur blessing
and let me tell ya
trown rods cant
count ur blessing
yea youre lucky that its still driveable....
heres my ****:
girl that was with me at the time said "are you sure it didnt just stall? try starting it again!"
heres my ****:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot »</TD></TR><TR><TD CLASS="quote">
How the hell did you do that!!!! Looks like it had split in half!</TD></TR></TABLE>
basically the con. rod broke off, then continued spinning on the crank and ripped through both sides the block.
this motor was boosted on for a few years now... she went out with a ******* bang though... RIP....
sorry for hijaking the thread
How the hell did you do that!!!! Looks like it had split in half!</TD></TR></TABLE>basically the con. rod broke off, then continued spinning on the crank and ripped through both sides the block.
damn tchleung....can't get g2ic at work; SO sorry to hear. thankfully she's still driveable, and hopefully the damage inside isn't as bad as it sounds.
i'll be keeping an eye out for updates as you have time to make them.
I had the same **** happen to me. It was also a JDM B16 and the oil pump gear shattered. Thank goodness I was using Mobil 1 syn. That **** saved my engine but the turbo died
Live and learn. Now I have an Oil pressure guage and if that sucker goes down, I will shut the car down immeditely.
My turbo feed was Tee off the Oil pressure but was done the Endyne way(Extension off the block to a Tee so the Oil pressure sensor was not grounded. Boy did I learn a lesson from that.
Well good luck on you new build man. I know your coming back fighting right??
don't give up!
